Results 1 to 10 of 28
Thread: Upgrading wheels. Why stay with 17" instead of moving up to 18"
    Charter Member verified
    Sept. 1991
    Mason, MI
    Smile Upgrading wheels. Why stay with 17" instead of moving up to 18"
    I like the style of the stock 1 gen R/T TT rims, but want to get something lighter, as mine are getting worn out in more than one way. Do I stick with 17x8.5 for ultimate weight loss and economy in wheels and tires? Or do I bump up to 17x9 with 255/40 wheels? Or make a bigger jump to 18x9, and live with the higher up costs of rims and tires. I am only interested in making a little nicer looking, well handling daily driver street car, without making a huge investment.
    The pluses I hear about 18" is that they match the larger curvature of the wheel well, and that it often allows for better spoke styling if a more aggressive or concave face is desired.
    The plus I see with 17" is lower cost, but can still have wider tires if I go 9".
    Does the 1/2" wider tire of the 255 really make much of a visual difference?
    Geordon
    [SOLD] Black '92 R/T TT
    Tein H springs
    K&N Airfilter
    (119,000 miles -- original owner)
    17"s clear the strut with wider tires...
    larger rims allow larger brakes though :| WAHHHHHHHHHHHHHHHHHH
    1996 GTO, Owner since 2003.
    Colorado
    Get some 5zigen FN01R-C. 17X9. It will change the look of your car and they are pretty light and won't break the bank. Also...they look great on a 3S.
    Sept. 1991
    Mason, MI
    Quote Originally Posted by blackjdmpower View Post
    What is on your car, in that pic? Those look close to what I am looking at. The Advan RS are way out of my price range, so I was looking hard at the GTC01 Hyperblacks, however, Enkei has no stock in the 17x9. I could wait awhile, if I knew they were coming back. If the PF01 were in hyper, instead of bright silver, I would probably go that route to save on weight and cost.
    In the 5z, I like the 6 spoke GN+ which TT Eric has, but those are not manufactured in 9". I think the FN01R-C leave the wheel too "open" or bare.
    I could go cheap and get some Rotas. They have some nice 17x9 in DPT and G-Force
    http://www.wheeldude.com/catalog/pro...oducts_id=6300
    One advantage I see of the 17", is if I move up to 9.5 wide, I could mount 265/40/17, which are a more common size than 255/40/18. With a 17" I would go with a slightly lower profile to reduce the amount of tire, but with 18", I would go (relatively) higher profile to make up for the 1" loss on the rim. Maybe I should just buy TT Eric's set, so he can upgrade to 18s?
    Colorado
    I've got Advan RS in 18X9. What is your price range? GTC01 is a good choice. Me personally, I dislike any rota wheel.
    TD04 Upgrade & Billet TD05 Upgrades
    Hudson, WI
    I've got 5zigen fn01r-c's. 17x9's on the car in my sig. But my old stealth had 5zigen fn01r-c's 18x9.5. I have a set of the 18x9.5's sitting in boxes that I need to sell
    Sept. 1991
    Mason, MI
    The $2100+ for a set of Advan RS is a bitter pill to swallow. So far, I have gotten a delivered price of $1460 for GTC01 18x9, which is hard enough to take. The $900 price of Rotas is quite comfortable, but in the end, I am not convinced I will be happy with them. If the GTC01 were in stock at 17x9, I would probably take it.
    If I use Tein H springs (or must I stay at full stock suspension), is there any reason I can't do GTC01 17x9.5 +38mm with 265/40R17 (Dunlop Diressa DZ101) tires all the way around? I think the +22mm will be woefully off. Or, is this combination going to hit inside or stick out past the fender, or cause grief with steering?
    Hudson, WI
    My last 92 Stealth Had tein S tech springs w/5zigen fn01r-c 18x9.5 et 35mm. 265-35-18's and I'd say it was a perfect setup. Here's a pic or two so you can see what that size and offset looks like w/teins.
    Sorry I dont have any better pics at the moment, I'm at work :/
    Advanced Tech? verified
    the 17x9.5 +38 may cause strut clearance issues. from my calculations, it will be awful close and may make contact.
    the one problem i forsee changing to a non-standard tire size is that it may render your spare useless if there is a significant difference in rolling diameter.
    Sept. 1991
    Mason, MI
    I was afraid of that. Might have to suck it up and get the Advan RC 17x9.5 with +35mm offset, like The Hustler. However, isn't the Gunmetal a flatter, darker color than the Hyper? Or do I put the silver on my black TT?
    Hadn't thought about that. I have only used the spare once, anyway. Guess I will have to rely on AAA's 100 mile flatbed service.
