Results 1 to 10 of 22
Thread: could use some insight into a lifter tick question
    No BS Feedback Score 0 hotGTO's Avatar
    Sorry if you care, I could be lying anyway!
    NJ (south)
    My TT lifter tick gets crazy loud then almost silent then crazy loud and it seems random... I know there is a solution to fix the tick, but why is the racket so random?
    Dave
    91 Stealth TT- Pampena Stage 2 short block, rebuilt heads, Solid mounts, MBC, Vac reduc, hotwired, Blitz FATT, 4.5" FIPK, TurboXS BOV, Stainless Downpipe, Race pipe, Borla exhaust, AHDS, 500 lb clutch, JDM 25 spline 5 spd/tcase, Short Shifter, EVO leather knob, 18" Mazdaspeed wheels, Front Splitter, in dash touch screen bluetooth/navigation/DVD...
    94 3000GT DOHC - Nitrous express proton series w/ upgraded solenoids, dash mounted datalogger, in dash touch screen navi w/bluetooth, IPT end clutch, high performance trans cooler, Translab shift kit. SOLD
    Texas
    You have sludge most likely. Change the oil and use CD2 Oil detergent in place of a quart of oil. Go drive for about an hour. You will smile.
    Just to be safe though, when they get loud, is your oil pressure normal?
    NJ (south)
    I have found that with heavier weight oil the oil pressure stays more stable and oil leaks less often, so I use a high viscosity full synth, and I just did an oil change to that from a water thin but very clean Mobile One that the PO used... on his oil, pressure would drop to near zero at idle, and lifter tick would be loudest after a long drive when parking, Now on my 20W 50 Castrol full synth I have not done the long drive yet, but on the short warm up and test drive the tick went from GONE to LOUD to quiet then loud then gone then quiet again... all while parked after a short test drive on the heavy synth... Oil pressure stayed higher and more constant on the heavier oil...
    Gonna drive a good 60 miles or so tonight and see how she sounds throughout...
    NJ (south)
    PS, I also know that pressures run low at idle anyway, and the the stock guage is far from accurate. That's why I am not quite panicking at the low oil pressure yet...
    Forum User Feedback Score 0 mikeyVR4's Avatar
    Gilbert, AZ
    Yeah lifter tick is random and comes and goes which is a good thing because a constant noise can result to a more complex issue. Your oil pressure should never drop to 0 or the minimum line on your gauge, even at idle.
    Solution? Get some 99 Lifters. 3SX is selling them for dirt cheap right now so you should try to grab some, I did .
    http://www.3sx.com/store/comersus_vi...dProduct=12153
    Texas
    lose the 20w50 and run a high quality HDEO in a proper viscosity and a good filter.
    dont make me explain why. i no longer have the time or patience.
    steve
    97 VR4 12.41 on stock turbos
    91 MR2 13.80 at stock boost
    91 stealth TT with a couple bolt ons
    and a laundry list of others....
    I have been running Brad Penn all season and havent had a single tick out of it this year, used to get it here and there last year with the Eneos.
    -Austin@STM
    And the list goes on...
    Pueblo, CO
    I am using Rotella-t 15w-40. Colorado has extreme heat/cold diferences and is actually rec's to use 20-50! Mine never ticks, ....but im using 99 lifters
    supporter
    Feedback Score 3 (100%) OhioSpyderman's Avatar
    Dayton, Ohio
    Curious as to the price per quart...
    Bob.
    Last edited by OhioSpyderman; 09-20-2010 at 08:16 PM. Reason: Wanted a response from Austin :)
    95 Caracus Red Spyder VR4
    Stock 18" 6 Spoke Chromies
    Indiglo Gauges
    92 Wheat Beige Metallic Stealth TT..Winter DD!!
    Oldest son - 94 Danube Blue VR4
