Results 1 to 10 of 26
Thread: Installed Stack Pro-Control Gauges
    Forum User Not Verified Feedback Score 0 SilverJester's Avatar
    I installed some new Stack Pro-Control Gauges (boost, water temp, and oil pressure) and thought I would share. These things are pretty cool, they don't require a control module like defi's. Each gauge can trigger 2 separate functions (e.g. the water temp can act as a 2 stage fan controller). Each gauge has 4 warning levels (2 low and 2 high), which will change color to any color you preset for level 1 warning and flash at you for level 2 warnings (hi and low colors can be different). In the pictures below the blue is what I choose for my low warning color and red for high (car was off so water temp was cold and I haven't hooked up the oil pressure sensor yet). It also has a peak recall that is remembered even after you turn the car off (as you can see my car is having some overheating issues )
    pics:
    My one issue with them is that they are bright! In this shot you can see them next to my EL gauge cluster overlays (which used to match perfectly with my posports in white):
    I'm not sure if they can be dimmed...the instruction are kinda unclear about the dimmable lighting mode. "Dimmable: In this mode, the white wire is used to set the intensity of the dial lighting from full brightness down to off." I'm not sure if that means they are dimmed or if it just turns off the lights.
    P.S.
    You can also choose the color of the gauges during normal operation (not in warning mode), I just like white. But you can choose from red, green, yellow, blue, purple, turquoise and white.
  2. The Following User Says Thank You to SilverJester For This Useful Post:
  3. #2
    Why? Because Race Car. verified Feedback Score 0 akotten's Avatar
    Wichita, KS
    Looks good! Where did you get your main gauge cluster overlays?
    91 R/T TT
  4. #3
  5. #4
    Wichita, KS
    OK, thats what I thought. Are they only indigo or can you get them to display in pure white?
  6. #5
    i LOVE stack gauges
  7. #6
    August 2009
    San Diego, CA
    How accurate are these?
    https://car.social
  8. #7
    Interesting to note that the oil pressure gauge uses an autometer sensor. The water temp was was right on with my data logger.
  9. #8
    supporter
    STACK FTMFW. Did you find these in that other thread? lol, I thought I was the only one with a 3s that wanted these. How was the install, besides the unclear bits in the instructions?
    And yes, They should be dimmable... I'm not sure how, but I know they have a dim function. Call up STACK and ask
    Yeah prob the same thread you saw them in
    I emailed stack (tried calling and they didn't have tech support, just an automated message). I'll play around with the white wire that is suppose to dim and/or turn off the lights this weekend when I have some time.
    Each gauge has a fair amount of wires in the "harness" 9-10 wires. But they don't come wrapped together. So I spent a good amount of time taping up wires together to form a neater harness. But aside from that, the install was easy.
  11. #10
    supporter
    Ok, sweet. I'm wondering if there's supposed to be a resistance put on that wire, or fed the voltage from the dimmer rheostat... I wouldn't pump voltage into it until you know for sure, lol.
    Sounds like a pretty easy install, thanks!
