Results 1 to 10 of 26
Thread: Guess who gets to pull the O2 housings??
    you know you like it Not Verified Feedback Score 0 Chris GTO TT's Avatar
    Sacramento CA
    Angry Guess who gets to pull the O2 housings??
    This guy...yup thats right went to replace the O2 sensors and the rear one fucked the bung up so at this point i'm pulling the housings and just going to replace them.
    wanderlust Feedback Score 0 bridge's Avatar
    Chi-town/ATL
    have fun! i broke a stud fri. i forgot to add heat to the equation after spraying pb blaster.
    Hitokiri Battousai verified Feedback Score 0 Jeremy C's Avatar
    June 2002
    in the desert
    you can't heli-coil it?
    Sacramento CA
    nope brought all the threads from the housing out with it shit looks like a clean untapped bung LOL
    June 2002
    in the desert
    then you should still be able to heli-coil it. proper heli-coil requires you to tap the hole bigger then put the coil in. If it didn't take too much extra material there should be enough to tap it out. I had to tap heli coil all 3 of the trans mount holes due to them getting all buggered up from so many pulls.
    Sacramento CA
    right but what O2 sensor would fit into that larger hole?
    Get the right helicoil and it will work fine. Otherwise its pretty easy to pull the rear O2 housing
    steve
    97 VR4 12.41 on stock turbos
    91 MR2 13.80 at stock boost
    91 stealth TT with a couple bolt ons
    and a laundry list of others....
    Sacramento CA
    This also gives me an excuse to gut the precats and fix the leaks at my down pipe. so its not a big deal really.
    Sacramento CA
    So after 5 months my car is done, both O2 sensors replaced and replaced the motor mounts with poly mounts while I had it that far apart. The good news the new O2 Sensors seem to have fixed my light throttle hesitation at low rpms.
    ~2006
    Pittsburgh, PA/Wheeling, WV
    Glad to see it fixed your issue after all the work! I think I need to change my O2s as well
    How do you like the poly mounts?
  • Resources
  • Events
  • Groups
  • Information
  • History
