Results 1 to 10 of 12
Thread: Wiring(non-automotive)
    Forum User Feedback Score 0 jbuhrman's Avatar
    Dec 2005
    Williamsport, PA
    Hey I need to wire up something.
    I have a plug such as the far right on this picture
    http://www.homedepot.com/hdus/en_US/...quirements.jpg
    And I have a 3 wire 220 volt appliance.
    Which wire goes to which prong??
    TN
    I not 100% sure but, the two top prongs are power wires (110v each) and the bottom one is the ground wire.
    Dec 2005
    Williamsport, PA
    Ive been talking with Mike(VR3.9) on FB and I have been told I made a bad purchase(230V Mig welder) and Im trying to use it at my apartment which is normal home wiring which will not work for my plan/wants.
    TN
    Their right, I assumed you already had a 220V outlet and just need to wire a plug.
    Here a nice write up:
    http://www.xomba.com/how_to_wire_a_220v_wall_outlet
    Dec 2005
    Williamsport, PA
    Quote Originally Posted by dbest671 View Post
    No, I only have a normal 110V outlet but was going to use a step up transformer.
    You would be better off making an outlet than using a step up transformer.
    supporter
    Turn the power and grab each wire to figure out which is power and which is ground.
    Seriously, there has to be instructions online somewhere. Just have to googlefoo it.
    Dec 2005
    Williamsport, PA
    Quote Originally Posted by TocVR4 View Post
    I live in an apartment so hacking into the wall is not really an option I can use
    I think what Ill do is just pack it up and put it in the closet and pick up one I can use with normal wall outlet
    Sthrn NH/Eastern Ma
    This is one of those simple questions that's not so simple.
    First off, let me say that the write-up that was posted has several errors (only some were pointed out in the comments). For one thing the panel he's coming out of is wired wrong! Please do not follow his
    advise, he doesn't know what he's doing...
    Now some questions:
    Did your new appliance come with a plug? Or does it have lose wires hanging out of it?
    What are the ratings of the new appliance?
    Do you have access to the circuit panel, and permission to add to it?
    What is the capacity of the panel, and is there room in it for the new appliance?
    (both physical slots for a new two pole breaker and capacity to handle the new appliance)
    What kind of construction are you going to have to run the new wiring through?
    Is this a dwelling (house) or garage? Commercial? Will there be gas or other hazardous/explosive material around?
    Setting up a welder at a rental apartment is kind of an ambitious project. You might want to re-think it. Even if you get it going where can do any work? In the kitchen? Maybe a friend's or parent's garage would work out better?
    Because of the variables involved, and the liability, I doubt you'll find anyone that knows what they're doing offering free how-tos on the interweb...
    Steve (Yup, I'm a licensed electrician... )
    Dec 2005
    Williamsport, PA
    Quote Originally Posted by Steve '92ES View Post
    Now some questions:
    Steve,
    Thank you for the reply, Im just going to either sell or pack up the current welder and get one that will work. Then when we get a house(we just moved to CA so didnt have time to look around enough) then do some wiring(if we buy Ill just have an electrician come and wire a outlet for me so I dont screw it up/die)
