Results 1 to 8 of 8
Thread: Will 03-04 cobra wheels fit a 1g VR-4
    Crimson Jihad Not Verified Feedback Score 2 (100%) Disrupter's Avatar
    Tried searching but couldn't really find anything on these wheels (18x9) but found a bunch of stuff on the 17x9's. Here are the specs:
    et +26mm
    p.c.d 5x114.3
    c.b 70.7
    And if someone could confirm the wheels in this picture.
    Thanks!
    CAUTION: Over Boosting May Cause Accidental Orgasm.
    1993 Mitsubishi 3000gt VR-4
    Bump??
    I have the 17x9 versions. I believe Yogurt! was running 18x9's without an issue on a 2G
    I believe I have seen other people running the 18x9 versions with no problems. That is what I would love to have some on my car, but I want the chrome. lol
    -Driftus Maximus- Not Verified Feedback Score 1 (100%)
    Corunna, IN
    Quick question, 18x9.5 with an offset of 30mm. Will theystick out the same as 18x9, 24mm offset?
    Howell, MI
    They'll stick out worse than the 24mm offset. I have the 17" replicas (not sure the offset) and they clear the calipers by a lot.
    http://www.discounttire.com/dtcs/infoWheelOffsets.dos
  7. The Following User Says Thank You to B-Man For This Useful Post:
  8. #7
    I don't bite Feedback Score 0 familyMAN's Avatar
    Southern IN
    Plug in the specs of tires/wheels you want to compare here...
    Wheel/tire size calculator
    1992 Kilder Green VR4 - First 4G swap in a 3S. 2.0, auto, awd. 9.65 at 143mph. Top5 3S quicklist. Quickest and Fastest single turbo 3S.
  9. #8
    Corunna, IN
    I ran the numbers on the 18x9.5 with 30mm offset and the backspacing is 6.4" compared to the stock 6.3". So they shouldn't stick out to much. I'll be looking into a set of those now.
