Results 1 to 10 of 12
Thread: Help with front oil return line.
    Member Feedback Score 0
    So.. is there some secret voodoo magic to getting to this guy? I took apart my intercooler pipes, front heat shield on the turbo, and the intake for the turbo and I still can't reach around and get to the return line. I tryed from the under side and started removing the downpipe, but it got dark so I figured I would get some input before I did any more dissasembly.
    Any tricks of the trade anybody wants to share with me, or should I just keep taking things apart until I figure out how to get to it?
    supporter
    Which end?
    You trying to replace it, or just get one end off?
    And the list goes on...
    Trying to replace it. One of my friends dented it in a little bit when we were removing my oil pan to take the dent out. Having trouble getting to the end attached to the turbo.
    Forum User Not Verified Feedback Score 0 SilverJester's Avatar
    I don't remember it being difficult to get to...but maybe try removing the radiator and fans. That frees up a lot of room.
    Texas
    Oh yes, this is a pain. Good luck.
    Alright, I'll remove it today and see if that frees up the space I need to get to it.
    Texas
    Quote Originally Posted by Zaroth View Post
    You are still going to have issues even with the radiator and fans out of the way. Honestly, the best and easiest thing would be to unbolt the turbo from the manifold, unhook your oil feed and coolant feed and return, and since you are replacing the return line, just pry the turbo over for better access to those bolts.
    Uggh. Should I remove the turbo with the radiator in or should I just take all that out anyways? I guess it would be easier if I took the radiator out, but then I have to drain it and all that bs. I miss my garage.
    supporter
    You can remove the turbo with the radiator in, but it's a royal pain. You may as well remove it.
