Results 1 to 10 of 22
Thread: transmission cooler?
    Iowa
    Lightbulb transmission cooler?
    hey guys i am in the prosses of hand building a transmission (300m parts, torsion base center diff, LSD, and brace) no i had a crazy idea come into my head and i was wondering if anyone else had the same ideas or have tried it. i was thinking about fabricating an cooler for it. use something like a 19 row cooler that i uses AN10 lines to and from it. using the drain plug hole as the hot side and fill plug (or make own hole) for the cold side. may need some sort of external pump or something to make it work.
    what do you think?
    Squivelicious Not Verified Feedback Score 1 (100%) AaronVR4's Avatar
    February 2004
    West Texas
    Before going through with any project like this, test the temp of the fluid. May not be worth messing with.
    Iowa
    any idea what acceptable range would be?
    3SNJ Pres Not Verified Feedback Score 0 91STT's Avatar
    Nov 2005
    Jersey City, NJ
    Unlike an automatic trannies, these manual trannies to not have any clutch packs or electronics in them that would that could be damaged by elevated fluid temperatures. I don't see a benefit with using one for our applications. Using the drain hole can be a problem unless you decide to fabricate a skid plate to reduce the possibility of the line or fitting being snagged and torn off. Just my 2
    It sure looks stock, so it must be.
    Click Here for 3SNJ Group Discussions
    Maryland Lighthouse Challenge 2015
    supporter
    95% sure it will be a waste unless you track the car for a long period of time.
    July 2007
    Columbus, OH
    Unaware of why this would be needed, I dont know of any TTs running them. Matt, IPO, Trevor, Ray and so on. Cant think of any of them running them (correct me if one of them does) and those are some built cars, which if you're pushing your car harder than that, well what are you doing?
    Current cars: 94 SL-AWD, 95 VR4, 94 VR4 (parts car), 95 VR4 Spyder (fixing)
    Past cars: 93TT-Parted, 92TT-Parted, 94NA-Parted, 95TT-Parted, 93SL-Parted, 91VR4-Sold, 91VR4-Sold
    STEALTHS ARE LIKE A TWIN BROTHER, GOOD FOR PARTS!!
    I believe that Tasmaniac was looking into this, basically there are a lot of high powered cars but how many of them are taken out on the track...Id be keen to see if any of the track guys have logged temps. with regards to withstanding elevated temps, it's more a case of how long before the lubricating properties of the oil break down and you start to grind metal on metal (speeding up synchro death and bearings etc).
    anyway I don't know! curious to explore it though!
    1996 GTO, Owner since 2003.
    verbose and bellicose Not Verified
    supporter
    Feedback Score 8 (100%) IPD's Avatar
    I made the biggest mistake of my life
    wtf?
    i'm supposed to be the only AWD 3/s with a trans cooler.
    "He that would make his own liberty secure, must guard even his enemy from oppression; for if he violates this duty, he establishes a precedent that will reach to himself."
    - Thomas Paine
    "This would be the best of all possible worlds if there were no religion in it."
    -John Adams
    "I must study politics & war that my sons may have liberty to study mathematics and philosophy".
    -John Adams
    "Christianity is the most perverted system that ever shone on man."
    -Thomas Jefferson
    "I contend that we are both atheists. I just believe in one fewer god than you do. When you understand why you dismiss all the other possible gods, you will understand why I dismiss yours."
    -Stephen F. Roberts
    "Never attribute to malice that which is adequately explained by stupidity."
    -Hanlon's razor
    "The greatest trick that Islam ever pulled, was convincing the world that it was benevolent."
    -Anon
    Are you Auto?
    Forum User Feedback Score 0 Apache's Avatar
    Billings, MT
    I would worry more about our transfer cases than our transaxles. They have a bad tendency to spit the fluid in them out the breather hole when driving at high speeds for an extended period. Of course... that's not to say that a cooler for the tranny doesn't peak my interest too...
