Results 1 to 10 of 24
Thread: 93 motor will not turn, just rebuilt, just installed.
    Forum User Feedback Score 0 ichihollow's Avatar
    ok, so i went to start my car today, didn't turn. the motor will not turn, i'm a little concerned about this, because before i mounted my transmission, i made sure the motor turned after i did the timing. after(and while) i mounted my transmission i made sure to turn the motor to make sure it continued to turn. I dropped the motor yesterday, it's fully assembled and all hooked up, i go to turn the key and nothing. tried adding a battery, nothing. adding another car, nothing. adding yet another car, nothing. put a socket wrench on my crank, wont turn. I'm not sure whats going on, and i really don't want to have to pull my motor out again.
    EDIT: already removed the spark plugs and tried again with no success. Anyone have a good idea, i'm about to put some oil or diesel or sea foam or something in the cylinders to try and get the motor unstuck.
    LETS EDIT AGAIN!!!: 92 R/T ATX tranny, 93 R/T block converted to be a 92 block.
    Rochester, NY
    Did the starter click when you turned the key? Or did you really get nothing at all?
    When you tried to turn the motor by hand, did you have the trans. in gear by chance?
    Just stupid things to look for.
    '97 VR4 - 19t, Chrome, Pump 93, 22psi, DD, Since '06
    '95 SL - 150k+, clean, reliable
    '06 Envoy SLT - Black, clean, DD
    '98 Expedition EB- Work/Winter horse
    '93 VR4 & '94 R/T - Projects
    starter clicked once, not the repetitive click i'm used to hearing with a low battery.
    i tried turning the motor by hand with the car in park and neutral, both should have allowed me to turn the motor.
    3/S: So bad ass they don't have to use chinese stars to pick locks and steal cars.
    RX7: Umm... yeah, I always shift at 7k.(sold )(Killed by dumb ass)
    Honda: "More forward please!"
    Take the belts off and see if it will rotate. If not you'll have to pull the trans.
    steve
    97 VR4 12.41 on stock turbos
    91 MR2 13.80 at stock boost
    91 stealth TT with a couple bolt ons
    and a laundry list of others....
    Quote Originally Posted by VR4 View Post
    damn, suppose it's better then pulling both.
    Quote Originally Posted by ichihollow View Post
    Wait a sec...doesn't the torque converter use bolts? If the engine doesn't rotate with the belts off, pull the tc bolts out and see if you can rotate the tc independant of the engine. If you can (should be able to with all bolts removed) try rotating the engine again...if you can't then something is going on in the engine.
    I the tc doesn't rotate pull the trans.
    will it be safe to try and move the TC by the starter, or should i try another method?
    On another note.....if the engine won't rotate...how did you get the torque converter bolts in?
    Feedback Score 12 (100%)
    Maybe the TC bolts aren't tight and they jammed themselves against the block. Try manually turning the crank counter clockwise.
    Forum User verified Feedback Score 1 (100%) TooFast4Radar's Avatar
    Quote Originally Posted by Hans View Post
    I second this - makes the most sense to check that first.
    - Volvo V50 T5 6-Speed
    - Porsche Cayman S 6-Speed
