Results 1 to 8 of 8
Thread: thermostat stuck
    thermostat stuck
    Im having hard time taking the thermostat out its stuck in there , any tips ?
    I dont want to brake the seal because Im going to use the mugen low temp stat and I need to use the old seal from OEM stat.
    Any help is greatly appreciated
    got it off. mugen is in and Im assembling it all back but there was no gasket (6N) beetween thermostat cover and housing ???
    Can I use some sealant beetween the cover and housing to seal it off (6N)?
    Is it a must to use sealant or gasket in there given the fact that there was no gasket in there and it did not leak ?
    Texas
    No, but why run the risk? It is very hard for metal to seal on metal. If there is any bit of it that isnt level or flush, it wont seal. This is what gaskets are for, to give the metal a softer surface to make a seal.
  7. The Following User Says Thank You to blindmist For This Useful Post:
  8. #7
    Forum User Not Verified Feedback Score 0 SilverJester's Avatar
    You probably had an o-ring on the old thermostat. I had a gasket in mind but I think it's a 1st gen thing (or maybe even an early 91 thing). I think most of these cars don't have a gasket, just an o-ring to seal it. I ended up going with rtv because I couldn't find a gasket in a reasonable time frame, it's working just fine.
  9. The Following User Says Thank You to SilverJester For This Useful Post:
  10. #8
    Assembled it with RTV
    Thanks for the help
