Results 1 to 10 of 18
Thread: Spyder Hydraulic Hose HELP!!! Same one keeps busting.
    TN
    Exclamation Spyder Hydraulic Hose HELP!!! Same one keeps busting.
    My car is at the shop being repainted in some areas. I stopped by today to be
    informed that there was a hydraulic leak somewhere. By the amount of hydraulic
    fluid he described, I believe one of the hoses has busted again.
    We have replaced the same hose at least 4 times now. Two were craptastic ones
    to just get us by. But the last two were OEM. Is there something I am missing
    to be busting the same line? It is the pink hydraulic line going to the RH
    tonneau cylinder. We bled the system each time we replaced any hoses and
    refilled with aeroshell. I only seem to be having problems with the passenger
    side hoses for the right side of the tonneau cover.
    Thanks for any help,
    April
    have you auto configured the system after you replaced the hose ?
    http://www.3sx.com/faq/manuals/Servi...Supplement.pdf
    JNS Engineering verified Feedback Score 1 (100%) Jimvr4's Avatar
    San Jose, CA
    Need to get Marc over on these boards. He answered this question on 3000Spyders
    TN
    Quote Originally Posted by mb7050 View Post
    No, because I just got the cable the other day. Am I supposed to auto configure after replacing just the hoses?
    TN
    I posted the question on the Spyder group also. I don't think it is from anykind of rubbing because of the location on the bust. It looks like a hose blow-out, there is no rub marks on the hose.
    San Jose, CA
    Quote Originally Posted by dbest671 View Post
    I don't think auto configuration has anything to do with hoses. It just adjusts the limits for moving the top / tonneau after mechanical changes are made.
    why would oem broke many times ?
    TN
    Thanks Jim for the cable also... do you want the other one back?
    Could there be something wrong with the cylinder which would cause back pressure or something? When I bleed the system everything seems to go through o.k. We have probably raised the tonneau cover at least 20 times since replacing the hose in question.
    I dont know but i was loosing fluid somewhere and after i auto configured it it doesnt lose any fluid anymore . Im not expert here you are
    I'm Kind Of A Big Deal verified
    Feedback Score 8 (100%) Emilie@GZP's Avatar
    I'll direct Hans to this thread... he may be able to help.
