Results 1 to 3 of 3
Thread: Clutch Problems?
    OKC
    Clutch Problems?
    Hey guys so I believe I'm having an issue with my clutch. Last night when driving home I notcied that I seemed to be getting a bit more chatter than normal. When I pulled boost in second gear it sounded like my clutch just started rattling uncontrollably. when I let off the gas it stopped. Now I have put a stage 3 spec clutch in roughly 300 miles ago. I haven't abused the clutch and I really avoid trying to ever ride the clutch. Someone locally had mentioned possibly the slave cylinder. Any ideas?
    Forum User Feedback Score 3 (100%) toddrs93's Avatar
    Hagerstown,MD
    sounds more like internal trans noise, unless it stops when you push the clutch in, which would point more towards a throw out bearing. Its usually not a slave cylinder(hydraulic) issue unless you are losing fluid, feel a difference in the pedal, or have difficulty getting into gear.
    OKC
    Well you were close... It's my rod bearings. Wasn't making a noise until high rpm,s and I mistakened the sound for unusual clutch chatter. So looks like I'm the newest member of the spun bearing club.
