It's not that hard when you weigh as much as a paper clip.
Definitely the ridiculously low weight. 400hp and 2k pounds is around 10 flat, then you need 600hp if 3k lbs and 800hp if 4k lbs to run 10 flat. Weight is huge. He is under 2k probably. If he weighs say 1800lbs he only needs about 170whp to run 12.7.
**these are just quick calculations using a generic 1/4 mile calc just to show that if you are very light you dont need much hp to run a 12.7 and go 106mph
92 Eagle Talon TSI AWD Auto = 10.61@127.8 (1.4 60ft)
94 3000gt SL 8:1TT 5spd getrag = 11.87@123 (1.8 60ft)
91 3000gt VR4 13gs = 11.61@115 (1.59 60ft)
Civics can be made quick cheaply. Buy one for next to nothing. Do some power mods on a nonpowerful motor, and then (this is the best part) rip everything off that pop can to make it weigh as little as possible. Boom! You have a high 12 second car that looks atrocious, sounds like a beehive over a megaphone, and is practically undrivable on the street all for $2000.
Power to weight. The have gone A LOT faster NA...
1993.5 Supra TT 6sp Hardtop -- old school 74MM setup: 10.4 @ 138MPH 1/2 mile - 166MPH - new setup #'s soon! [Previously 468WHP & 11.3 @ 125MPH stock twins]
1994 Supra TT 6sp -- 11.8 @ 118MPH basic BPU
1999 3000GT VR-4 -- 12.5 @ 108MPH 100% stock w/ Chromed ECU tune
2003 Denali XL -- Grocery Getter & Tow Rig -- Runs 13's! (mpg)
Formerly:
1994 Supra 6sp - 72mm, VPC, stock longblock -- 722WHP & 10.36 @ 139.5MPH
1993 Stealth RT/TT; 2003 Corvette Z06; 1997 3000GT VR-4; 2002 Corvette Z06;
1999 3000GT; 1992 Stealth RT/TT; 1993.5 Supra TT; 1993 3000GT; 1992 3000GT VR-4;
1998 Trans AM WS6; 1992 Talon TSi; 1993 3000GT VR-4; and many others..
I can think of a stock turbo 3S running tens... (STM and Austins car).
Weight helps.
1995 Dodge Stealth R/T TT, Dark Green ext, Dark Int, 1 of 20 available to the US.
Mods: E3 16G turbos, FMIC 3" in/out, Spec Stage 3 clutch, RPS Billet Aluminum Flywheel, test pipe, MSD 8.5mm SC Wires, 3rd Gen lifters, EGR Delete, 3SX EGR Block off plates, FAIV Block off plate, Blitz DD BOV, Hotwire Walbro 255 Fuel pump, Map ECU, Dual Pillar pod w/ AEM Wideband and AEM Tru Boost, Halo Hybrid Data logger, Supercar Engineering 1/2 billet aluminum Shift fork, fresh 1/2/3 friction rings, custom solid engine mounts, Ultra Slim 15" Radiator Fans, KYB Struts, 3" Straight pipe exhaust single out.
Looks: DCC Conversion, White face glow gauges, Tein S Lowering springs.
Sound: Infinity components up front, infinity 10" sub in back with Smokin' VR4 corner sub box, Pioneer CD/MP3 HU, Kenwood KAC-8452 AMP.
3SGTO.ORG Paid Member
It`s funny you know, when I go drag racing the whole pit area talk to each other, have a laugh and enjoy ourselves regardless of what car we race. That makes it the most fun for me.
Why can`t people just be happy for the bloke and the time he`s achieved?. Plenty of VR4`s around that can`t scrape a 12 second run from what I`ve seen..
Plenty of 11 second all motor Hondas in Oz.
Scotty
