Results 1 to 10 of 10
Thread: Battery question. (CCA)
    August 2003
    Uniontown
    I understand what CCA (cold cranking amps) are.
    Now, given I want to go smaller to reduce weight with a good battery. What is the lowest CCA that would allow me to turn my car on in the winter with very little fuss.
    I have seen it where I am down to -8 F before, but that is more rare than the winter typical just below freezing.
    I also plan to have a pre-luber to get oil circulating before I crank. If that even matters. And possibly having the battery in the trunk.
    August 2003
    Uniontown
    Bump...
    1PNCHMN Not Verified Feedback Score 3 (100%) Unknownvr4's Avatar
    I cranked my car with a small honda battery before..
    But if your looking for small..
    http://streettunedmotorsports.com/pa...ll_battery.htm
    -Benn
    Master Elite KIA Technician
    1994 3000GT VR4 - 2012 Lexus IS250 F Sport - 2008 BMW 335i
    1988 Toyota Supra Turbo - Hers
    Follow my build thread here
    supporter
    Just from seeing a few cars with batterys in back the loss getting to the starter is going to take a normal CCA. My brother had a Neon that had a battery in the trunk when he got it. The car cranked over hard even in the summer and it was ran with very heavy gauge wiring. He finally got tired of it and moved the battery back to its stock location and the change on crank over speed was ridiculous.
    If you want to go smaller then keep it in the engine bay. Smallest I would personally go is 500 cca, and that may even be pushing it on colder days.
    My battery is in the back also and even the Honda battery had no problems cranking it.
    supporter
    Feedback Score 6 (100%)
    I like my group 51 battery because it is big enough to not die if you leave the dome light on overnight, but a lot more compact and lighter than stock.
    August 2003
    Uniontown
    I want to get a Braille Battery. I have just been trying to figure the size. Id imagine I could leave it in the bay if I go smaller than a stock batt. I think mine weighs around 40 something. So a battery that is 17 or 20 lbs should be good. The specific one I am looking at is, http://www.braillebattery.com/index....eries/b3121c/# . It has 550 CCA and 742 CA.
    Has anyone bought a Braille?
    The Panda Not Verified Feedback Score 0 vr4tune's Avatar
    Washougal WA/Portland OR
    I don't have any problems with my battery. It is a 15lbs Odessey PC680.
    August 2003
    Uniontown
    What is that gigantic white/gray wire coming from the positive, along with the red?
    stereo.
