Results 1 to 7 of 7
Thread: Need a gearbox case
    Roo fuckers anonymous verified Feedback Score 2 (100%) GTO Assassin's Avatar
    Perth, Australia
    Unhappy Need a gearbox case
    Actually, I need the case.
    I know one of the boys over east has a case and box for sale, but I dont have that money handy. Mike - do you still have that box lying around? If you do, I would love those casings if you dont want them. and still have them. The gearbox shop said it would be too risky to weld as it's the t-case area and will heat up causing more problems.
    Thanks.
    Scotty
    Melbourne, Australia
    I think if mike has anything it would be for a 6 speed.
    Waiting install
    Build Thread
    QLD
    Hi Scotty, I would consider taking it to an engineering / welding works and getting them to take a look at it , they should be able to grind it out and TIG weld it without any problem , regardless of location on housing . This should be a lot cheaper and easier than replacing that bell housing section. ( maybe 1 hour labour @ $ 100.00 ? ) I brought an mid case section off Supercar Engineering second hand , but i don't think he has a bell housing in stock any more .May be worth sending him an Email to enquire .
    Good luck
    Adrian
    Sometimes things go wrong !
  5. The Following User Says Thank You to Ack For This Useful Post:
  6. #5
    supporter
    Feedback Score 2 (100%) RealMcCoy's Avatar
    Medford OR
    I know you're looking for one on your side of the world, but if you don't have any luck, I've got a few of them...
    For what it's worth, I'd weld that in a heartbeat... It's not a stress crack from use, it split when the threads got wadded up. Weld up the crack, heli-coil the bolt hole, and you'll be set.
  7. The Following User Says Thank You to RealMcCoy For This Useful Post:
  8. #6
    Perth, Australia
    Roger that thanks guys. Like I said, the guys who put the case back together took it to their welder and he said not to. I'll take it somewhere else.
    Scotty
  9. #7
    As the TC bolts over it there is nothing stopping you from welding it then welding another piece of plate against it for extra strength.
