Results 1 to 10 of 23
Thread: Why does my car hold less than a gallon of coolant?
    Member Not Verified Feedback Score 0 3kgt1734's Avatar
    Alright. I drained my coolant to replace it.
    Went to fill it up and got less than a gallon in before it started over flowing. I started the car to let it circulate and the level didn't go down anymore. I'm pouring it directly into the thermostat/water housing
    Wtf? It is supposed to hold 8.5 quarts correct?
    how much came out?
    usually if you just drain it at the raidiator, you only get about half of it out. Most of the coolant is still in the block.
    And the list goes on...
    how much came out?
    Not as much as I thought should've. My coolant light is still on though.
    supporter
    Did you bleed it?
    A good bit remains in the engine.
    Texas
    Put some coolant in the overflow bottle, there is where the switch is for the light. 2ndly, you would have to unhook the bottom and top hoses from the radiator and run the engine to pump the water out from the block and heater core. Of course not for very long.
    Feedback Score 12 (100%)
    To drain the block, you are supposed to pull the block drain plugs... but they are a bitch to get to. With draining just the radiator, it will take less than a gallon. When doing a water pump, you will take about 2 gallons.
    Fowlerville, MI
    This.
    I'm Kind Of A Big Deal verified
    Feedback Score 8 (100%) Emilie@GZP's Avatar
    Quote Originally Posted by blindmist View Post
    Uh... that may not be a very good thing to recommend to people
    Current:
    2004 ML500 - Mommy Mobile
    1995 3000GT VR-4 - lawn gnome
    1999 3000GT SL - 7,436 miles
    FOR SALE:
    Agreed.
