Results 1 to 10 of 12
Thread: Radio Antenna Question
    So my auto antenna is broke and I'm looking to replace it with a Shark Antenna ( http://www.locustom.com/shark2_kit.htm ). My question is if I replace it with this antenna and buy the 14' long antenna cable can I delete everything in the picture below? If not, what all has to stay?
    Sorry for the crappy pic quality, its off of my phone...
    Thanks, John
    Forum User verified Feedback Score 3 (100%) 3000GTCSULB's Avatar
    You are correct. Let me know if you like it, I'm looking to get another antenna soon too.
    supporter
    Feedback Score 6 (100%)
    why would you use a different antenna cable? Just hook it to the stock one.
    I didn't know if using the stock antenna meant I had to keep any of those components from the motor... if it doesn't than I will just use the stock antenna cable.
    supporter
    yeah I'm actually doing this today, I'll let you know.
    supporter
    The antenna cable plugs into the factory power antenna setup, so, as said you only need a replacement antenna mast and it should plug right into the factory cable.
    Rancho Cucamonga, CA
    ^^^ what he said. I got the same antenna and just connected it straight to the cable, therefore tossing all of that stuff you pictured. I like it
    Oh, and almost forgot, tightening it down is WAY easier with a stubby wrench. If you have one now's the time to use it.
    Forum User Not Verified Feedback Score 0 heptone182's Avatar
    Jan 2011
    Hell Paso, Texas
    Anyone have an opinion on where the best place to connect the red wire off the Shark II would be?
    STEVE-O
    '92 VR-4 - '99 Front End Conversion - Galaxy White
    Warner Robins, GA
    I've replaced three antennas. The only issue I've encountered is loss of the "up/down" automatic feature when changing from radio to CD/iPod. With some aftermarket units, the antenna will remain up until the ignition switch is turned off. The factory set up will move the antenna down anytime the radio is not in use.
    JNS Engineering verified Feedback Score 1 (100%) Jimvr4's Avatar
    San Jose, CA
    Quote Originally Posted by BaadVR4 View Post
    I have a Kenwood DNX7160 and it was automatically moving the antenna up/down whenever the unit was turned on so I couldn't keep it lowered when playing the iPod. It does have two switched outputs that can be controlled so I used one of them to control the antenna relay. Now if I want the antenna up I can do so through the Kenwood menus.
