Results 1 to 10 of 11
Thread: Rod question
    supporter
    Feedback Score 1 (100%) FeaRpb's Avatar
    Rod question
    I was wondering how much power the stock rods could handle. Block in question,
    http://www.ipsmotorsports.net/produc...oducts_id=1970
    That one has stock rods.
    This one has Forged Rods,
    http://www.ipsmotorsports.net/produc...oducts_id=1969
    Texas
    The stock rods are forged from factory. I am not sure exactly what they can handle though. If you have a 2-bolt, it is recommended to upgrade to a forged crank before upgrading rods.
    Forum User Feedback Score 0 pos-vr4's Avatar
    Socal
    the stock rods had handle 600hp (with proper tuning), but i would not use them with the stock OE bolts. I would Install ARP bolts and have the stock rods reconditioned at a machine shop before i would run them at that level.
    More often than not, the machine shop bill plus parts is very close to a set of BC or 3sx rods, so most people go that route.
    Warner Robins, GA
    My H-beam 4340 forged rods have ARP 2000 bolts and are running in at least 4 engines of 600+AWHP. They are $550 shipped in the US. LMK.
    supporter
    I will possibly be in touch with you Baad.
    XLR8TOR Feedback Score 0
    Las Vegas, NV
    It is my understanding, after talking to the tech's at ARP, that you need to follow their torque spec's for their bolts and studs and not the torque spec's specified by the factory. [for steel, not aluminum]
    ARP bolts and studs need to be stretched by a certain amount in order to make the correct clamping force. Stock torque setting do not stretch ARP bolts enough to do that because of the steel that they are made of. Also, they recommend that you do not use any other lubricant on them other than their new "Ultra Torque" and you will be within 5% of exact torque on the first pull. I use it and the stuff in awesome but dirty and also has anti-sieze properties as will, like for exhaust nuts and bolts.
    ARP says that when using like stock bolts you are actually twisting the bolt while torqueing it. When you use studs the twisting action is not there and you get a straight stretch to torque.
    If you have never twisted an ARP nut onto an ARP bolt or stud by hand you are in for a surprise. It's like sex in your hand. You get what you pay for with ARP and you will sleep better at night too.
    I have ARP Studs on the bottom end and rods and ARP Studs on the heads of my build. That should hold everything in place.
    P.S. No I don't work for ARP.
    supporter
    Im just trying to think if stock rods will hold dr-750's to their max.
    DR750's cool kid club! Feedback Score 0 TT Eric's Avatar
    Ottawa
    Depends if you have gen1 DR750's or gen2, but you could be in the 700WHP area and the problem would be to have a lot of torque so much low (no other turbo set-up produce that much TQ down low on a 6G72).
    SoIMO if you're gonna to rebuild your engine and you want to daily drive your car, the best would be to put stock piston and a good set of rods (lighter possible), that set-up would allow you to have longivity and stay quiet (stock piston) and strong enough to avoid bending rods.
    Eric
    DR750's, DR stage III heads, DR Boost cooler stage 2, Denso 660cc, TE37SL +273'S Z1 , KWv3, Stedebani suspension buschings, SCE 13'' Stoptech, 2G rear brakes, Forged shortblock, 3SX cam gears, SCE racing oil pan, PST CFDS, RPS 6 puck, RPS Flywheel, ETS FMIC, 3'' custom quad tips catback, new leather seats heated, SCE center diff, Quaife, brand new tranny/tcase, Billet casings, Chrome ECU, Swaintech...
    Member Feedback Score 0 Lugnut's Avatar
    Coastal Delaware
    In the big picture it is believed that a stock bottom end will fail if you drive the car hard at 600+ wheel .. When it will fail of course is anyones guess !!!
    Texas
    Like I said, you need to have a forged crank before you change your stock rods. The cast crank will break or flex with stock rods.
