Results 1 to 10 of 16
Thread: Miss Fire. Need Help
    Lincoln Nebraska
    so driving home tonight I got a CEL
    code:active
    22(Crank Angle Sensor)
    code stored
    44(coil pack) rear pack not firing.
    I have a jdm ECU so shouldn't having leaking caps? Is it possible?
    Well I changed out coil pack and CAS with no results. Could the wiring to the CAS have an issue some where?
    I was driving down the highway and it developed a miss and CEL came on so I pulled over and found out that one coil pack wasn't firing well I started driving and once I got up to speed the CEL went off and everything was fine until I got about 5 minutes from home when it started doing it again.
    I drive a 92 TT
    Lincoln Nebraska
    Come on. No one has any suggestions?
    Real drivers don't use speed limits verified Feedback Score 2 (100%) Woz's Avatar
    Buffalo, New York
    well just remember order goes like this crank/cam > ecu > ptu > coil packs > plugs. I would make sure you have spark at all plugs. is it just random when driving or is it driving and just idling?
    Why would a JDM ECU be exempt from having leaky caps? It was built in the same factory with the same parts as a USDM ECU. If you suspect the ECU, pull it and check it.
    supporter
    Feedback Score 3 (100%) OhioSpyderman's Avatar
    Dayton, Ohio
    I agree TOTALLY with the above 3 posts. If you don't own a spark tester, get one, they're < $15.
    Removing the ECU takes all of about 10 minutes (I've removed the ones in our cars so many times, I do it in my sleep ).
    There are very good troubleshooting procedures laid out in the manual for testing coils and PTU's. If you don't have a manual you can find them online at 3SX.com (*thanks Steve!!!!*)
    Bob.
    95 Caracus Red Spyder VR4
    Stock 18" 6 Spoke Chromies
    Indiglo Gauges
    92 Wheat Beige Metallic Stealth TT..Winter DD!!
    Oldest son - 94 Danube Blue VR4
    Lincoln Nebraska
    I was unsure about the ECU. I do have the old ECU that came out of the car I know its bad. So what's a good place to send it to to get repaired? ( heard about AvPro? but I am still unsure of there services?)
    It misfire just idling I haven't tried driving it since this has happened. I did get manuals from 3sx the was the first thing I bought after I got the car.
    the top coil pack isn't firing at all but the middle and bottom do. When the car is running I tested CEL codes with my data logger (also from 3sx) and while running it gets an active code of 22 CAS and 44 coil pack (stored) I replaced the coil pack and CAS but with used units. So I will check them the next time I have a chance.
    Thanks for the help
    Buffalo, New York
    remember you have primary and secondary on coil packs.
    Lincoln Nebraska
    what do you guys recommend for a multi- meter and a good place to get an ECU fixed?
    Buffalo, New York
    Well fluke has a pretty damn good multi meter but anything will do for checking. You could go to radio shack and pick one up if you wanted to. I forgot where I got mine rebuilt at. Many people off these forums have gone there. I hope someone can help me with the name. Its a place in florida, charged I think 260, got it back the same week no extra charge. Many good reviews. You can search up on 3si about it. Ill try to find it though
    You're thinking of AV Pro and I am one of quite a few that refuses to recommend them.
    I recommend toddrs93. For what AV Pro does its a comeplete ripoff. Not to mention they don't even have the means to actually test the ECU.
