Results 1 to 8 of 8
Thread: Low-risk mods?
    supporter
    Feedback Score 8 (100%) j2k4's Avatar
    Low-risk mods?
    That's where I'm at, just now - if I hang the 13Gs on it, EBC, and do the necessary fuel mods next year, I'll definitely have a piggyback in there too, but in the meantime, I've decided to keep my eyes open for a set of converted DSM sidemounts (maybe go with oohnoo's?), bigger IC piping, cat-delete DP, etc.
    How will the car react, absent the piggyback?
    BlackStealth's LCDBC, Stillen DP/no cats, MTC 13Cs, oohnoo's DSM SMICs, FIPK, 3SX Y-pipe, Evo X BOV, Big Tyla's Ground Wire Kit, Chrome/flashable '98 SL ECU, Rebuilt Throttle Body by April, Ninja FP Hot Wire, FPR bypass, RC550s, Supra FP, Innovate WBO2, full vac-reduction, EGR delete, R. wiper-delete, Tein S-Techs, adjustable rear control arms
    supporter
    The car will perform a bit better, I'd say. The bigger IC & piping may hurt spool time (you have to pressurize a bit more volume) but it will help flow immensely, especially over the stock rubber crap. You'd also get the benefit of a much cooler charge temp, so less heatsoak, and less risk of knock from high charge temps. The DP will help significantly. Even with a shorty DP (non cat-delete, but no pre-cats) I picked up a few hundred RPM of spool.
    supporter
    About what I thought, especially re: spool, but is there any risk to the engine I haven't picked up on?
    I've been reading everything I can find, but as finicky as this platform is...
    supporter
    I never had any issues, 3s's don't seem to care too much until you start bumping the boost up.
    Oct 2010
    I have a very similar setup on my VR4 actually. 13Gs, downpipe with all cats gutted, dsm sidemounts with stock IC piping, and no piggy back. It's all stock fuel control and injectors. I also have some other stuff like cam gears, 10:1 compression, and exhaust, but that can't amount for TOO much more power right? My car is pretty quick. I don't even have any boost control hooked up, its just running the wastegate pressure, but it creeps up to 11psi by redline. It's good for 300+awhp this way, which is usually what a BPU TT running 15psi usually puts down.
    supporter
    Quote Originally Posted by deathsled View Post
    Ah.
    That's a step or two ahead of me - good!
    I may have a few more questions for you...
    GREASE BUNNY Feedback Score 0 Granny's Avatar
    VA
    When you said Low-risk mod I was going to suggest a wax job...on the car.
    supporter
    Quote Originally Posted by Granny View Post
    Low blow, Granny.
    I like those.
