Results 1 to 3 of 3
Thread: Maximal Performance Stage 2 TC Bracket
    Feedback Score 2 (100%) Maximal's Avatar
    Avoca, NY
    Have a few of these in stock and they're not moving as fast as I thought so I figured I'd get the word out some.
    These, in my mind, are the best bracket you can get. They're the beefiest by far and have the most mounting points. On top of that the price is rather competitive.
    This is essentially for people in between BPU and an all out build. If you're BPU our original bracket is probably enough for you as people have pushed their TC's into the low 11's and 10's without issue. If you want a bit more security though the Stage 2 is what you want. It will make your TC as close to bulletproof as you can get without going with an aftermarket case.
    Order here: http://www.maximalperformance.com/st...&productId=121
    2004/5?
    SW Connecticut
    I'll put it on the Christmas list
    Avoca, NY
    Good to hear.
    We also have gift certificates so if your wife/gf/family/friends aren't exactly good at buying things for your car that might be an easier option.
