Results 1 to 4 of 4
Thread: Fuel Pump Hot Wired; Bye Bye Knock!
    2004/5?
    SW Connecticut
    I just got done hot wiring my stock fuel pump today, and my engine knocking is finally gone! I'm really psyched.
    Original Symptoms:
    -My logger saw my fuel trims as Low: ~82(idle) ~90(driving), Mid: 110, High: Just under 120.
    -Occasional sputtering/hesitation under load
    -knock spiking to 20 counts now and again under load
    First: I checked for intake leaks despite the fuel trims looking like the opposite of a leak condition. No change.
    Second: New fuel pressure regulator:
    -Trims were fixed! Low remained the same, mid: ~108, High: 102.
    -Knock still remained, hesitation still remained.
    Third: I did the hot wire with the help of a friend, drove it around for about a half hour and got nothing more than a rare 1 count of knock. Problem solved! Throttle response seems faster now and the ride is overall smoother with no more hesitation.
    Fuel trims are now
    low: same as original at 82 but now does not fluctuate higher while driving, Mid: 96, High: 105
    I'm now contemplating re-installing the EGR system because I believe I heard this may raise and keep level my low fuel trim.
    Man, I can't wait to turn my boost up! I don't even remember what stock boost feels like. The car already seems quick and the boost is only at waste gate pressure.
    JNS Engineering verified Feedback Score 1 (100%) Jimvr4's Avatar
    San Jose, CA
    Good to hear! I've been having a similar problem that I first noticed when logging a dyno session. If you don't mind, check out my logs posted in the Spyder on the Dyno thread and let me know what you think.
    San Jose, CA
    Quote Originally Posted by Rom3BreaK View Post
    Found this reference which may shed more light.
    http://www.stealth316.com/misc/obdii_fuel_trim.pdf
    Elko, Nevada, United States
    I plan to hotwire my pump hopefully this weekend if weather prevails, I've got a bunch of rewiring to do since I keep draining batteries somehow and hotwire is on the list. Hopefully it will quell my random knock issue as well.
