Originally Posted by
MaxClass
These are going on my build as they came highly recommended by many others as second to none but not the cheapest. Great looking with the factory style plug ends that seal around the plug openings in the valve covers and extra heavy boots on both ends.
"MSD 8.5mm Super Conductor Wires"
* 40-50 ohms per foot of resistance
* High EMI suppression abilities
* Tough silicone/synthetic sleeve
* Durable, extra thick plug boots
* Dual Crimp terminals grip the wire and conductor
The lowest resistance and the highest EMI suppression.
Also
Part#: 32709
Don't think you could go wrong with these.
MaxNote: When checking your manual timing always back the crank counter-clockwise about an eighth of a turn from TDC then bring it back to TDC clockwise to make sure there is no slack in the belt. All your timing marks [dots on the cam gears] should line up with the arrows on the valve covers at that time. Best of luck.
