Page 1 of 6 123 ... LastLast
Results 1 to 10 of 59
Thread: Single turbo VR4
    1PNCHMN Not Verified Feedback Score 3 (100%) Unknownvr4's Avatar
    Single turbo VR4
    A few months ago i blew the rear stock turbo on my car. I was looking for a turbo upgrade anyway and i was bouncing back and forth between 19ts, 16gs, or single turbo... I saw the thread where someone used a 350z manifold to build theirs about a year ago. After i re read the thread a few times i jumped in on it and bought a set of 350z manifolds to weld up to my flanges. Since then ive been fabricating everything for this.
    Just continuing this thread where i left off on 3si. I have fuel pressure now, but it dies off quickly. Turns out im also leaking gas from where the injector seals on the rail; hopefully this is a quick and easy fix so i can tune the damn thing for idle!
    Mods:
    -Holset HX50 turbo
    -Custom turbo manifolds
    -FMIC
    -"3sx" 38mm wastegate (probably will need to ditch this and get a bigger one )
    -Precision 680cc injectors flow matched
    -Hotwired "supra" fuel pump
    -Aeromotive FPR
    -Crushed 1g dsm bov
    -Emanage Ultimate (stage 3 wired)
    -HKS EBC
    -A'pexi N1 Exhaust
    -Spec stage 3 clutch
    -Unorthodox Racing lightweight flywheel
    -Solid motor/transmission mounts
    -Rebuilt transmission
    -Rebuilt motor
    Forum User verified Feedback Score 1 (100%) TooFast4Radar's Avatar
    Pics or permaban from the new forum
    Sounds fairly similar to my car's transformation....
    - Volvo V50 T5 6-Speed
    - Porsche Cayman S 6-Speed
    Forum User verified Feedback Score 1 (100%) Monster Stealth's Avatar
    Fort Wayne, IN
    Very nice. I second the pics. Did you have to move any wiring, or add some heat wrap since I am assuming this is a over the trans setup?
    9B+93-13.2@108
    16G+E85...?
    the cake is a lie
    Pics are up. No wiring is moved. I do have to get a heat reflective sheet to cover the wires
    -Benn
    Master Elite KIA Technician
    1994 3000GT VR4 - 2012 Lexus IS250 F Sport - 2008 BMW 335i
    1988 Toyota Supra Turbo - Hers
    Follow my build thread here
    Member verified Feedback Score 1 (100%) billbrown72's Avatar
    louisiana
    whats up Benn....any luck on getting car lined out?
    No, when i put the injectors in i put them on the lower plenum first then the rails on top which must have messed the o rings off because it kept leaking, then one of the bolt holes on the lower plenum to bolt the rails onto stripped out. Good thing i have like 5 of them but now i got to go to the store in the morning to get at least 3 new fuel injector orings
    louisiana
    damn damn damn
    13t's, complete fuel upgrades, afpr,fmic,maxumal solids,hyperblack saleens,safc2, greddy ebc,
    Woot! supporter Feedback Score 0 L_P's Avatar
    Toledo OH
    Interesting. Hope it turns out awesome!
    1995 Dodge Stealth R/T TT, Dark Green ext, Dark Int, 1 of 20 available to the US.
    Mods: E3 16G turbos, FMIC 3" in/out, Spec Stage 3 clutch, RPS Billet Aluminum Flywheel, test pipe, MSD 8.5mm SC Wires, 3rd Gen lifters, EGR Delete, 3SX EGR Block off plates, FAIV Block off plate, Blitz DD BOV, Hotwire Walbro 255 Fuel pump, Map ECU, Dual Pillar pod w/ AEM Wideband and AEM Tru Boost, Halo Hybrid Data logger, Supercar Engineering 1/2 billet aluminum Shift fork, fresh 1/2/3 friction rings, custom solid engine mounts, Ultra Slim 15" Radiator Fans, KYB Struts, 3" Straight pipe exhaust single out.
    Looks: DCC Conversion, White face glow gauges, Tein S Lowering springs.
    Sound: Infinity components up front, infinity 10" sub in back with Smokin' VR4 corner sub box, Pioneer CD/MP3 HU, Kenwood KAC-8452 AMP.
    3SGTO.ORG Paid Member
    Forum User Feedback Score 0 jbuhrman's Avatar
    Dec 2005
    Williamsport, PA
    Ouch...
    Atleast you caught the fuel issue early.
    Now im getting fuel and it runs but the AFRs are all over the place and it doesnt seem to like to run after a few seconds.. ill try unpluging the maf here in a second but it doesnt want to start right now because its flooded
