Results 1 to 10 of 10
Thread: Modular Fuel Pump Hangers
    Earth
    Thumbs up Modular Fuel Pump Hangers
    Anything from a stock replacement to dual walbros or Densos, and easy to install!!
    These are currently in stock and ready to go.
    They will allow you to use 1 or 2 pumps, Walbro or Denso (supra, stock, Kyosan, etc) and include theyre own independent power/relay wiring harnesses (commonly referred to as a Hotwire kit, but this is so much better i dont want to call it that). Each pump has its own dedicated circuit from the battery + to the pump, and back to Battery -
    Yes, you read that correctly, you can use 2 denso pumps without modifying the tank hole!
    - Kit includes comprehensive VIDEO instructions
    - All electrical components are rated at 40amps. The wire meets SAE specs for automotive underhood use.
    - Wiring is sealed through the bulkhead using Chemical resistant epoxy potting compound
    - Harness and pump frame are terminated with professional grade connectors and pump can simply be unplugged for easy removal
    - The pump hangers are constructed of 12gauge steel and Zinc plated
    - Each assembly has two #6 an feeds and a #6 an return
    - OEM Fuel gage and warning floats remain in place
    This is what you get for $325
    If you want to use this as a stock replacement because yours is destroyed or damaged, i will include a kit that will allow a single pump and use all the stock hardlines for an additional $10. The kit includes a feed hose and caps for the unused AN ports.....SOLD OUT
    Please specify if your battery is in the front or rear, and if you need the ten dollar single pump option
    Please note that even if you get the single pump option, you will still be able to upgrade at a later date to 2 pumps without any additional parts, everything to run 2 pumps is included in every kit
    Dealer Inquiries Welcome
    verbose and bellicose Not Verified
    supporter
    Feedback Score 8 (100%) IPD's Avatar
    I made the biggest mistake of my life
    wayne,
    so can i put a -6/-6 > -8 an y-fitting on this and run -8 from tank to block? if so...i think i may need one of these.
    Earth
    Yes, you will need 2 short -6 hoses, but yes.
    Hose to run stock feed as return (at the tank side) is included
    Elko, Nevada, United States
    Very tempting...I just installed a walbro last weekend and my pump hanger is pretty rusted..I think I'll wait till I can use full advantage of 2 pumps tho. Nice product!
    supporter
    i'll take one, wayne. my battery is in stock location under the hood.
    would it be possible to get you to toss in just enough extra -6an line so that i can y-fit them without having to run extra lengths? can i run dual bosch as well, or just dual walbro / dual denso?
    need your paypal.
    Earth
    The only hose i have is like whats in the above pictures, and i dont have any fittings
    I dont think anyone has tried to use bosch pumps, my guess is the second one wont fit through the hole
    My paypal is "topgeareng at gmail dot com"
    These are very nice, I have one.
    Earth
    There are 45 of these out there. The last 5 are currently in my possesion
    supporter
    funds sent.
    Earth
    Thanks!
