Results 1 to 10 of 11
Thread: Cruise Control help needed
    Forum User verified Feedback Score 1 (100%) BadHabit's Avatar
    N.C.
    O.K. ,I just got the 92 stealth back on the road and I need some one to point me in the right direction.When I push on the cruise control switch the light comes on in the dash bezel but,I cannot seem to get the CC to work at all.Can someone tell me what to look for?
    Thanks in advance...Mike
    Forum User supporter Feedback Score 0 nogreatloss's Avatar
    Lakeland
    Does the "cruise" light come on as well?
    Banned verified Feedback Score 0 ictponder's Avatar
    Owosso, MI
    I'm going to assume just the ASC light comes on but not the cruise light. I'm having the same problem and would like to get it fixed so please someone help this guy lol.
    Forum User Feedback Score -1 (0%) skater334's Avatar
    2006 - 94 Base model ; 2008 - 94 VR-4
    San Diego, California, United States
    It's the sending unit, it needs replaced. Same thing happened to me last year.
    http://www.stealth316.com/2-stim.htm Look under fuel system.
    Quote Originally Posted by Atrosity
    Quote Originally Posted by CandyAppleVr4
    3S's have been turning normal people into mechanics since 1991. =P
    yeah you can say that again
  5. The Following User Says Thank You to skater334 For This Useful Post:
  6. #5
    Check all your vac lines, my cc didn't work and I was sure it wouldn't be a simple fix and since I never use it anyways I just left it blah blah blah..
    So anyways I was doing some engine work and was pulling hoses and noticed there was a tear in one of the lines , fixed and now cc works perfectly.
  7. #6
    Forum User Not Verified Feedback Score 0 $$$PIT's Avatar
    March 2007
    Muskogee, Oklahoma, United States
    If the cruise light is coming on, I would also suggest checking your vacuum lines. There is a little nipple that seems to get broken off of the vacuum pump. Mine did and it was an easy fix. I fixed mine 2yrs ago and it's still goin'.
    Get a male/male vacuum line fitting, drill out the nipple (don't go to deep) with a bit slightly smaller than the vacuum line fitting and press in the fitting. Then reinstall your vacuum line. Saves you from having to buy a new vacuum pump.
  8. #7
    December 2009
    Fox Cities, WI
    Make sure the plug is plugged into the cruise control box....Thats what was wrong with mine. The ASC came on and the cruise did not work
    Seriously. The plug to the box is your problem . Dont go swapping parts just yet
  9. #8
    supporter
    If the ASC light comes on, but not the cruise light try lifting the clutch pedal with your foot as you try engaging the switch. There is a switch on the clutch and also the brake that will shut the cruise off if not engaged right.
  10. #9
    N.C.
    ASC light comes on, but not the cruise light is exactly what it is doing ,so I see I have a couple of things to try in the morning..Thanks for the help.I will let you all know they results.
    Thanks in advance , BH
  11. #10
    supporter
    If it turns out to be the switch on the cruise it may just be the clutch pedal being out of adjustment. Thats actually what was causing a similar issue for me.
