Results 1 to 6 of 6
Thread: what size tires would you run
    Forum User Not Verified Feedback Score 1 (100%) ntcmpjg's Avatar
    Bamberg, Germany
    I have a 94 R/T N/A with a set of Eibach lowering springs what size tire would you guys use
    http://www.discounttiredirect.com/di...7.5&vid=003882
    3000GT of Europe
    www.3sofeu.org/main
    Cherry Hill Mitsubishi Coupon Code- 3SE
    supporter
    I wouldn't run those wheels in the first place because they are too narrow. If you already have them then just run 245/45/17. Anything wider isn't going to be recommended.
    verbose and bellicose Not Verified
    supporter
    Feedback Score 8 (100%) IPD's Avatar
    I made the biggest mistake of my life
    245 on a 7.5" rim? seriously? i wouldn't go above 225's.
    supporter
    7.5 is usually the minimum wheel width recommended by tire manufactures for 245's. 245's would be fine.
    supporter
    that's interesting, considering 3/s's with 245's stock came with 8.5". even my 225's came on 8". possible? sure. i sure as faak wouldn't run it.
    supporter
    100% sure. Summit Racing is one thats good to show tire manufacturers specs on minimum and maximum wheel widths for the tire. Everyone I looked at showed 7.5 minimum and 9.0 maximum.
