Results 1 to 10 of 11
Thread: 12V tap for center gauges?
    Forum User verified Feedback Score 4 (100%) Frostedbutts's Avatar
    Is there any good place other than the rheostat connector to tap a 12V wire somewhere near the center gauges? I am installing new center gauges and my rheostat connector is already tapped to hell.
    Ignition harness
    supporter
    The purpose of hooking it to the rheostat is so they will dim if you dim the gauges, and so that they will only come on with parking lights.
    Oh, I see thanks. I will need to tap them into a source that is always lit then.
    Texas
    Gauges don't draw a lot of power. Especially digital ones with LED lighting. So the stock wiring is more than sufficient.
    10amp fuse is way to high of a rating for just three gauges. A 3 amp fuse would be more than enough if you are just running the gauges alone. Remember digital gauges are rated in milli-amps not amps
    You match the fuse to the wire, not the project. Gauge of wire over length = fuse amperage
    Charles Town, WV
    Cigarette lighter? Stereo switched 12v line?
    1995 VR4 Coupe
    and a 95 too! Feedback Score 0 deemo99's Avatar
    April 2005
    Door Peninsula
    I used the cig lighter 12V with a 10amp inline fuse to my AEM's in center. Ground and power both run along pass side along console.
    1995 3000GT VR-4, 1 of 6 identical
    DR-16Ts, ARC2, 550s, supra pump, GReddy FMIC, Tomei BOV, RPS max full face, 3SX fuel rail loop, AEM wideband boost & oil pressure in stock location, Stillen DP, gutted rear pre-cat, Tanabe Touring Medallion catback, HHH datalogger, active aero sim w/3SX splitter, vac redux, Tein S KYB GR-2, Maximal control arms, 3SX poly bushings, ss brake lines, IPS rotors carbotech pads, ABS delete HKS EVC 6, HKS DLI, Maximal powder coat, 5hp chrome twin turbo plate, BSLCDBC
    1999 3000GT VR-4, 1 of 65 identical
    Jack-stand mod for now.
    it's probably fair to say that I've seen more cranks than a lot of other people on here.
    Never finishes any verified
    Wake Forest, NC
    If you replaced the center gauges then use the stock wiring for the +12v When I hooked up my Prosport gauges I used all of the stock wiring so I wouldn't need to run random wires all over the place. Looking at the wiring diagram it will be the black-white wire.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    Feedback Score 2 (100%) Maximal's Avatar
    Avoca, NY
    Yep, I used the stock wires for my power feeds on the center gauges.
    Wake Forest, NC
