Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: strange engine noise with video
    Forum User verified Feedback Score 0 Caswell239's Avatar
    AB Canada
    ** now offering $200 for who Evers idea leads to a solution**
    this is directly above the intake manifold and sounds like its coming from under the rear valve cover. strange how its intermittent.
    cant get the vid to embed so heres a link
    http://www.youtube.com/watch?v=iePgFw9vGMQ
    **********see page 3 post 30 for latest info,with new vids after new lifters were installed***
    Damn! That sounds bad! The whole engine sounds a little noisy. 1st do you have a dent in the oil pan? It definitely sounds like a lifter to me but I'm not sure why it's intermittent like that unless it's getting oil starved or something. I don't think I would keep running it. I would do the 60/120K service and replace the valve lash adjusters/lifters.
    When is the last time you changed oil and what kind of filter are you using? If it is a fram filter get rid of it.
    Do fram filters have shitty filtration?
    AB Canada
    Changed my oil like 300'kms ago it looked fine no specs. yes I have a fram filter. I'll look into the 120k service
    AB Canada
    Ps no dent
    AB Canada
    Anyothers??
    Rochester, NY
    Just a pesky woodpecker, don't worry about him.
    Break out your stethascope and find it.
    '97 VR4 - 19t, Chrome, Pump 93, 22psi, DD, Since '06
    '95 SL - 150k+, clean, reliable
    '06 Envoy SLT - Black, clean, DD
    '98 Expedition EB- Work/Winter horse
    '93 VR4 & '94 R/T - Projects
    i would pull the plenum and rear valve cover, my stealth actualy had a few of the rocker arms somehow pop off the lash adjusters. it made a similar sound, but mine was constant and didnt come and go.
    the basic go fast bits...
    Tuned by Ray Pampena
    Just a fun Daily Driver.
    Forum User Not Verified Feedback Score 0 -dLs-'s Avatar
    Oct 2010
    Ukiah, Ca, USA
    It sounds just like my engine and it turned out to be the rocker ... cant call it the arm, as its squashed between the cam and the lash... mine was intermittant however itd go faster as you revved due to being loose and floating. Worse case is damaged cam and replace the rocker is what i had.
    -dLs-
