Results 1 to 8 of 8
Thread: Bypass Hose came off - need advice
    Forum User Not Verified Feedback Score 0 atarirx's Avatar
    Aug '99
    CT
    Quick background: I was driving home from work last night in my 95 VR4 when I noticed that upon acceleration the turbos were not engaging, just heard a lot of rushing air. I still had normal power otherwise so decided to take it easy. A couple minutes later I noticed black smoke behind me and the car started to run rough. By the time I got to an exit ramp I couldn't get it much over 45mph. As I was pulling off the exit the car stalled.
    I popped the hood and found that the bypass hose that connects to the BOV had popped off. I reattached it and was able to make it home (~2 miles) but the engine was running rough. Once at home and with the help of a friend we started pulling things apart. All that seemed to be bad was the spark plugs which are completely black on the ends.
    So my questions:
    Is there anything else that could have caused the bypass hose to come off other than the obvious (loose clamp?) The car had been running flawlessly up to this point, turbos pulled strong, no sign the BOV was dying.
    Besides replacing the spark plugs, is there anything else I should worry about? Visually everything else looked as it should.
    Thanks in advance.
    99 base - original owner 60k // 94 SL - sold // 95 VR4 Spyder - sold // 95 VR4 - 73k // 95 VR4 Spyder - sold // 91 SL - sold // 96 SL - sold // 93 SL - sold // 94 SL - DD - 61k // 96 RT/TT - #35/57 - 77k
    ~2006
    Pittsburgh, PA/Wheeling, WV
    I doubt any damage occured. Should be fine
  3. The Following User Says Thank You to HLxDrummer For This Useful Post:
  4. #3
    after you change the plugs, be sure to change the oil. it is likely contaminated with gas.
  5. The Following User Says Thank You to i3igpete For This Useful Post:
  6. #4
    Feedback Score 12 (100%)
    I'm with that guy!!!
  7. #5
    Aug '99
    CT
    Yes, already picked up new oil! Forgot to mention that. Sounds like this will be a relatively quick and painless fix. Thanks for the responses.
  8. #6
    Texas
    LOL. This is the first time this has happened?
    I cant count in one day how many times I have blown my y-pipe off until I got t-bolt clamps.
    I am not meaning this in a belittling way, I am just amazed that this is the first time it has happened.
  9. #7
    1PNCHMN Not Verified Feedback Score 3 (100%) Unknownvr4's Avatar
    When you blow a pipe off or something like this happens, unplug the maf and drive it to a place where you could reattach said pipe.
    -Benn
    Master Elite KIA Technician
    1994 3000GT VR4 - 2012 Lexus IS250 F Sport - 2008 BMW 335i
    1988 Toyota Supra Turbo - Hers
    Follow my build thread here
  10. #8
    Aug '99
    CT
    Is it worth cleaning the plugs? They only cost a few $$ each but mine are less than a year old. What would I use, just rubbing alcohol or something stronger like break cleaner?
    And yes, this is the first time this has happened to me! The engine is 100% stock with only 66k and never raced so not so amazing really.
    EDIT: Decided not to try cleaning the plugs and instead just put in new ones. Car is back together purring again. Phew.
  • Resources
  • Events
  • Groups
  • Information
  • History
