Results 1 to 5 of 5
Thread: Fuel Pump Assembly
    Fuel Pump Assembly
    While installing my walbro, I had to fix the low fuel light wiring. Upon tightening down the nut, it snapped off from the assembly;
    Are these posts replaceable, or is it a whole new assembly time?
    I am not sure if you can get those exact ones again, but there are plenty of options to replace the wiring, without replacing the entire assembly.
    And the list goes on...
    You can drill it and remove the insulation and install two electrical and fuel resistant bushings (SBR washers) on each side of the assembly. On top of each SBR washer install a stainless screw and nut with (4) stainless washers and split them with ring connectors (sandwich one ring from the top and another from the bottom). It will work just dandy for you.
    You can epoxy the repair after you test it for added protection.
    December 2009
    Fox Cities, WI
    I would just drill a hole next to the post and run a wire through it and JB weld it . When I broke mine off in my Talon a few years ago my mechanic just sodered the wire to where it broke...Not sure if thats an option for you.
