Results 1 to 10 of 11
Thread: Should I get EManage?
    Forum User verified Feedback Score 1 (100%) Amphiron's Avatar
    I've been looking at these for awhile, not sure if it would be a worth while seeing as I am N/A. I just really wanna experiment with tuning before I do a turbo build. However would I be able to get any gains with a stock N/A?
    Fowlerville, MI
    You'd see very minimal gains unless you ran an alternative fuel (race gas, e85)
    Forum User verified Feedback Score 0 WidowMaker's Avatar
    Emanage is a decent piggy-back unit, but for ease of use and excellent results I would suggest getting an Apexi S-AFC2 or NEO with updated firmware. If you need any thing outside the scope of a regular AFC, you should probably go with a standalone unit like AEM EMS.
    -Steve
    Hmm, E85!!! I got some research to do now. Is there a guide for such a conversion?
    Charles Town, WV
    Bigger fuel supply - injectors, pump, hotwire, lines, etc.
    The e-manage is usable on NA and TT, so if it fits in your build for NA and TT mods, and you have the cash to blow, seems like a good idea to test it out while the setup is still in the early stages.
    1995 VR4 Coupe
    Well wouldn't I need more air first?
    August 2009
    San Diego, CA
    Can't you remove your maf with speed density to get more airflow?
    https://car.social
    Texas
    Quote Originally Posted by Atrosity View Post
    Yup. If you are planning to go TT, you can do a TT conversion without having to get a TT ECU I believe. Saves your money in the end. I love my Emanage Ultimate and I am just now only about 3% into understanding it and using it to its full potential.
    Charles Town, WV
    Quote Originally Posted by Amphiron View Post
    I may be off but I thought that E85 needs more fuel per part than pump gas (20% or so?), so you'd need more fuel even with the same amount of air.
    I know it has bigger payoffs at higher power levels, not sure what it would do for an NA. I've seen SD on the Ultimate, but never checked to see the if Blue can do it.
    Can`t do it on the Blue because it doesn`t have a Karman Hz output table, the Blue needs a Hz input to modify; the Ultimate doesn`t.
