Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: No rev past 4300.
    No rev past 4300.
    Plugs where gapped to 35, vacuum reads 17/18 at idle, new coolant temp sensor, new wires, new plugs, new FPR, still a fresh engine. If I hit the throttle 100%, it will start to pop and backfire. If I slowly get into it, 50% throttle, it will rev to redline.
    Texas
    Sounds like you have a 2-step. :P
    Quote Originally Posted by blindmist View Post
    That's exactly what it sounds like...literally.
    Still running that coil on plug setup ? I have a strong feeling its your ignition if your timing and fuel are spot on...
    Quote Originally Posted by mb7050 View Post
    I took the COP system off. It's 100% stock now. I am going to go get some coils later today as I am thinking the same thing...
    supporter
    Feedback Score 1 (100%) FeaRpb's Avatar
    I am having the same problem.
    I had the exact same issue when I bought my car. So glad thats gone. I replaced and upgraded SO many things along the way of figuring it out. Went maft, changed injectors, changed tuning devices, and ext. Basically it boils down to 3 things. Messed up fuel filter, messed up FPR, and either leaking turbos (or in hin sight pressurizing my crankcase).
    Coop
    supporter
    Well I guess I will replaced my fuel filter, check out my FPR and do a boost leak test.
    Boost leak is NOT the same as pressurizing the crankcase or leaking turbos.
    Coop
    supporter
    Go on
