Results 1 to 10 of 11
Thread: Is the knock sensor grounded to the block?
    Forum User Not Verified Feedback Score 0 rawavr4's Avatar
    Easton
    I'm putting a new engine harness in my car because my old one has wires cracking everywhere and the knock sensor wiring is weird. It has the black and white wire coming off the plug. The white wire goes to the ECU and the black wire went about 10 inches into the harness and stopped. It went into a little plastic pocket thing next to the signal wire insulator. Is that normal?
    supporter
    Feedback Score 2 (100%) RealMcCoy's Avatar
    Medford OR
    The wire to the sensor is a shielded wire. The black wire grounds the shield.
    Easton
    Do you mean the shield grounds the black wire? I'm trying to figure out the best way to wire this in from scratch.
    Easton
    I'm still slightly confused. Sorry. So would I ground the black wire to the shield?
    supporter
    Medford OR
    The wire is sheilded all the way from the computer to the sensor... The black wire you see in the connector simply connects the sheild in the harness to the sheild on the sensor pigtail.
    Easton
    Got it. Thanks
    Texas
    Everything is fine, just leave it alone.
    Forum User Not Verified Feedback Score 0 Keyan's Avatar
    the knock sensor doesnt require a ground. it creates a voltage when a ping (knock) resonates from the block. the shielding prevents radio interference so the ecu can interpret the voltage correctly. the shielding NEEDS to be grounded.
    Easton
    So now I got everything plugged in, and I put the multimeter on the plug and both the shield and signal wire are grounded. Time to tear it back apart?
    Easton
    With the ECU plugged in, both the shield wire and signal wire has ground and a few ohms of resistance between each other. With the ECU unplugged, only the shield wire is grounded and there isn't any resistance between the 2 wires. Any thoughts?
