Results 1 to 9 of 9
Thread: gauges question
    the BOSS of jellow supporter Feedback Score 0 a2j's Avatar
    May 2005
    Dairyland
    gauges question
    I need the following: water temp, oil temp, oil pressure, and others...
    I will be putting them them in the stock locations (oil temp will go in "boost" gauge location). Can I use stock send units or not? can I just take the stock gauges out and replace with aftermarket ones? I will need oil temp sender but what about oil pressure and water temp?
    You cannot use the stock sending units for aftermarket gauges. I wish.
    May 2005
    Dairyland
    alright! next question... where would I put aftermarket water temp sending unit? best location. take out the stock?
    August 2009
    San Diego, CA
    For my gauges, I used the stock location for oil pressure and water temp. I can't stress this enough but do not spend money on cheap gauges. You get what you pay for, including inaccuracy. Do it right the first time and buy reputable gauges. In the stock location I have aem 52 mm gauges.
    https://car.social
    and a 95 too! Feedback Score 0 deemo99's Avatar
    April 2005
    Door Peninsula
    I also highly recommend the AEM 52's. Very accurate, fast and not too bright at night.
    1995 3000GT VR-4, 1 of 6 identical
    DR-16Ts, ARC2, 550s, supra pump, GReddy FMIC, Tomei BOV, RPS max full face, 3SX fuel rail loop, AEM wideband boost & oil pressure in stock location, Stillen DP, gutted rear pre-cat, Tanabe Touring Medallion catback, HHH datalogger, active aero sim w/3SX splitter, vac redux, Tein S KYB GR-2, Maximal control arms, 3SX poly bushings, ss brake lines, IPS rotors carbotech pads, ABS delete HKS EVC 6, HKS DLI, Maximal powder coat, 5hp chrome twin turbo plate, BSLCDBC
    1999 3000GT VR-4, 1 of 65 identical
    Jack-stand mod for now.
    it's probably fair to say that I've seen more cranks than a lot of other people on here.
    May 2005
    Dairyland
    I was asking about sending units location, not the gauges themselves
    I used all stock locations. The coolant sensor your swapping out is the black pluged one. It doesn't really matter which oil unit you swap out.
    April 2005
    Door Peninsula
    You can also use a sandwich plate for oil temp and press.....
    May 2005
    Dairyland
    if I will remove stock water temp sending unit to put in aftermarket, would that mess anything up? like signal to ecu or something else?
