Results 1 to 9 of 9
Thread: What is this on my air compressor!
    Banned verified Feedback Score 0 ictponder's Avatar
    Owosso, MI
    I just picked up this compressor for $60 and found these threads were half stripped. It connects a copper line up to the gauge junction box. What is it for and is it important?
    December 2009
    Fox Cities, WI
    Prolly not going to hold pressure like that
    Owosso, MI
    I fixed it. I cut off the stripped threads and got a new piece of copper pipe and compression fittings. Now the tank won't fill more than 30psi, but no leaks.
    December 2009
    Fox Cities, WI
    Nice.
    Melbourne, Australia
    30 psi isn't much. Mine fills to 200psi...... a rattle gun prob won't operate of that and it will constantly be on when ever you need to use it. How many HP is this thing? cus $60 is lot for a small 2nd hand compressor. If it's big mofo then you have a good find. Assuming you can get it to hold more than 30psi.
    Waiting install
    Build Thread
    Owosso, MI
    It's a 4.5hp direct drive 24 gallon tank 130psi max compressor. I replaced the regulator today and kept the original pressure switch. Also got an oiler for one side and a water trap for the other (2 outlets) but I need to get 2 couplers to extend them out a bit or they hit the regulator. I also had to make a new pressure check valve but local parts store sells copper pipe so no biggie. Still need to put a gauge in.
    December 2009
    Fox Cities, WI
    Im sitting at my dads shop that has a bunch of pneumatic and hydraulic of gauges....I could ship you a 150psi one with almost any thread you need right now.
    Owosso, MI
    I have some gauges but if you have some in-line gauges and a couple swivels how much would you want for them?
    I'd kinda like it setup like this if I could get a regulator on each gauge, if not then just a single gauge on one side would work.
    Quick Connect < Swivel < Gauge < Trap < Regulator > Oiler > Gauge > Swivel > Quick Connect
    December 2009
    Fox Cities, WI
    I do not believe we have inlines...We do have a bunch of T fittings and regulators. You could give them a call at 920-766-0113 if you would like and tell them exactly what you need. Lonnie is a very very smart guy and could help you out no problem. Mention you know Tret
  10. The Following User Says Thank You to terrets For This Useful Post:
