Results 1 to 6 of 6
Thread: EngineRDS...cool stuff inside
    Stuper Moderator Feedback Score 0 HilbillyHomeboy's Avatar
    January 2003
    Cool EngineRDS...cool stuff inside
    Water Droplet Bouncing on a Superhydrophobic Carbon Nanotube Array
    Video from the paper "Bouncing Water Droplet on a Superhydrophobic Carbon Nanotube Array," authored by Adrianus I. Aria, Morteza Gharib, published online on ArXiv, Submitted on 7 Oct 2010: http://arxiv.org/abs/1010.1351
    The first two parts of the video show the impact dynamic of 30 microliters water
    droplet at different impact velocity. At low impact velocity of 1.03 m/s, the water droplet deforms upon impact and eventually bounces off completely of the surface of the array. At higher impact velocity of 2.21 m/s, the droplet breaks up into many smaller droplets and eventually bounces off completely
    The coefficient of restitution of water droplet at very low impact velocity can be seen clearly by dropping a water droplet on a slightly tilted carbon nanotube array. At tilt angle of 2.5 degrees the droplet skips off of the surface of
    the array multiple times without showing any sign of pinning on the surface
    of the array, as demonstrated in the third part of the video. The fourth
    part of the video shows the sliding/rolling behavior of the droplet along the
    surface of a U-shaped carbon nanotube array. The fifth part of the video
    shows the impact of two identical 14 microliters water droplets to one another on a U-shaped carbon nanotube arrays. Upon impact, these two water droplets, which come from the opposite direction, merge to form one larger droplet.
    All parts of the video were captured by high speed camera operated at
    various frame rates. The droplet was illuminated from behind with a diffuse
    halogen light. The droplet was dropped on the surface by at-tipped needle
    and the volume of the droplet was controlled precisely by syringe pump.
    This work was supported by The Charyk Foundation and The Fletcher Jones Foundation.
    So cool.
    supporter
    So cool, indeed. Nanotubes are pretty sweet, they're definitely going to lead to some serious advances in technology in the reasonably near future.
    I love watching things like this, you get to see what your actually seeing.
    And the list goes on...
    Man vs 3/S verified Feedback Score 6 (100%) R/T93's Avatar
    Kingston, WA
    I love seeing what I see!!
    haha, cool vid though.
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
    as a chemistry major i really cant wait till i get to learn about some thing cool like this. gen chem sucked, organic chem is ok, but this is sweet.
    i don’t know if any of you guys watch modern marvels on the history channel but there’s one episode on alloys. its insane how some of these metals were designed. i cant find the clip but one guy made a metal alloy that you can bend anyway you want, but once you add hot water it will go back to whatever shape it was originally in. he wanted to make car bodies out of it so that after an accident you could just hose off your car with warm water and the sheet metal would return to normal. ill keep looking for the clip so i can post it.
    the basic go fast bits...
    Tuned by Ray Pampena
    Just a fun Daily Driver.
    ya i've heard about that, i also read about Nissan (im pretty sure it was Nissan anyways) was developing a clear coat to do the same thing. They demonstrated with a peice of scotch-brite. Scrathed the hell out of the clear, them poured hot water over it and it was good as new. Would be awesome to have a car fix itself for once.
