Results 1 to 10 of 10
Thread: A bird trapped in my engine bay
    2007 (17 Years old ;)
    rio rancho (AKA Real Rathole)
    Is what my car sounds like when its on and idling. If I step on the clutch pedle then it goes away, so that makes me think its my though out bearing or something. I popped the hood an listen around the engin and it sounds like its coming from under my valve covers. Any ideas??
    If it goes away with pressing the clutch pedal then its going to be the throw out bearing. The only thing under your valve covers are well cams and valves and wont be affected by pressing the clutch pedal.
    Thank you Stealthee. Would it become a cause of catastrophic failure down the line? And why would it be making the noies. I just installed it when I did the clutch. Was I suppose to lubricate it or something?
    Yes you were. You were supposed to lubricate the inside of the TOB and the shaft it rides on.
    Your trans is going to have to come back out. If its already noisy then the TOB is going to seize making it impossible to shift.
    Thanks again Stealthee. The tranny going to be replaced any seeing how its cracked and leaking. So Should I replace the TOB or just grease it?
    owner since 2004
    cheshire, england
    EVERYTHING that moves, slides, pivots or rotates on a car SHOULD be lubed!
    Rice Patrol verified
    Lube...tis a wonderful thing.
    Boiler Up!
    may 2010
    West Lafayette
    Quote Originally Posted by Mean Green View Post
    That's what she said
    Certified boost addict.
    Quote Originally Posted by naptownvr4 View Post
    weeerd
    Turbo Pirate
    Savannah, Ga Area
    Quote Originally Posted by colt45 gto View Post
    *lubes his steering wheel* O_O;;;
    1993 3000GT VR4 :: Mods :: Forged Block, APR Head Studs, TD04 19T Turbos, 36x14x3 FMIC, 3inch custom intake, Dijon Prepipes, DeatschWerks FP HW, Fuellab Fuel Pressure Regulator , 560cc EVO Injectors, Adjustable Cams, 3SX Aluminum Flywheel, IPS Titanium Exhaust, 2x HKS Black BOV, Greddy E-01, Greddy Ultimate, AEM gauge A/F, SPEC Stage 3+ Clutch, Steel transfer case upgrade, Transfer Case Bracket, most sensors replaced, EGR block off, Solid and Poly engine mounts, Ground wire kit, Iridium IX @ .028, if it's metal its polished or powder coated, and some other stuff.
