Results 1 to 10 of 22
Thread: Grinding Noise from Passenger Rear Wheel...
    Anywhere from 0-35mph I hear a grinding noise. Its not constant it only happens for a portion of one cycle of the wheel. The noise is more noticeable when the brakes are not applied, when they are it just quiets down a little. Not feeling any vibration in the brake pedal, just in my seat. Anything above 35-80mph I can't hear it anymore. I bought the car with drilled and slotted rotors but I cannot see any cracks in them and they feel very smooth to the touch. I briefly looked at the dust shields as well, they look like shit and appear to be rusting out very quickly but they don't seem to be in contact with anything that is spinning.
    Does anyone have any ideas? The car is a 97 vr4 with exhaust, intake, tien s springs and 145k on the clock.
    Thanks in advance, John
    Where the dust shields bolt on could be rusted away and grinding. You cannot see that unless you take of the tire and I believe brake caliper. That was the case in my car at least.
    Ahhh, One last fix. And it would literally be perfect for ......prolly a week BUT! thats still a week of perfection.
    supporter
    Could be a wheel bearing, or it could be the brake pads themselves.
    did you check the back side of the rotors to check for any wear marks or groves?
    And the list goes on...
    Taichung, Taiwan
    Wheel bearing or the brakes should be the culprit.
    supporter
    Feedback Score 3 (100%) OhioSpyderman's Avatar
    Dayton, Ohio
    I just replaced the rear outer wheel bearings in my Stealth. The symptom was a noticable whine/grumbling from the rear at speeds ABOVE 35 mph.
    Just a heads up....
    Bob.
    95 Caracus Red Spyder VR4
    Stock 18" 6 Spoke Chromies
    Indiglo Gauges
    92 Wheat Beige Metallic Stealth TT..Winter DD!!
    Oldest son - 94 Danube Blue VR4
    1994 3000GT Original Owner. verified Feedback Score 0
    August 1994
    Bel Air, MD
    Quote Originally Posted by VR-4 0wnz j00 View Post
    What he said. ....also check the wear indicator on the brake pads.
    I have also noticed that I can drive for 10-15 minutes before the noise begins. Here are some pics of that rear passenger rotor.
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    Does anyone happen to know what kind of rotors I have? I bought the car with them already installed. They look kind of rusty...
    supporter
    Feedback Score 4 (100%) CoopKill's Avatar
    Jack the car up, pull the wheel, spin the rotor. You most likely have wheel bearing going out as mentioned. Mine did the exact thing and this is how I found out what it was.
    It will not tell you which bearing (inner/outer) it is, but while you are there it's best to do both. Should only cost $170ish. If it's way more than that look elsewhere for your work to be done. The bearing are in the $25 x 2 plus $18 for the seal give or take.
