Results 1 to 10 of 25
Thread: OBD1 Evoscan
    supporter
    Feedback Score 6 (100%)
    OBD1 Evoscan
    Does anyone have experience with the OBD1 evoscan cable and using evoscan?
    http://www.evoscan.com/evoscan-gps-o...i-/-aldl-12pin
    Why? Because Race Car. verified Feedback Score 0 akotten's Avatar
    Wichita, KS
    I have it...but I ordered it 1 day before I found out I have a lower bearing failure..so it will probably be some time before I will be able to test it out. Hopefully it wasn't a waste of money. Maybe you could test it for me? haha...of course returning it after the results.
    91 R/T TT
    Holland, Ohio
    Bump..
    I would also like this information.
    Zach
    MINE: 93 VR4 (currently BPU :evil2: )
    DAD'S: 92 Stealth TT (Winter DD) & 95 Spyder VR4 (SLEEPER )
    Brother's: 94 VR4 (BPU)
    Feedback Score 12 (100%)
    I'm not running their cable, but I do use evoscan with obd1. I have some old school serial cables and I just use a usb-serial adapter. I'd go with their cable as the adapter you need (if you have an old serial cable) is a PITA to get. I think I went through 3 adapters before getting the right one with some kind of special protocol.
    supporter
    what are your experiences vs say HHH
    SDSU Alumnus verified Feedback Score 4 (100%) bboyalan's Avatar
    Nov 2006
    Chula Vista SD, CA
    I could test this out the next time that I see an OBDI 3/S since I have the cables+software for all years. They are pretty much the same deal when it comes down to it, however, EvoScan already incorporates audible alerts and is set up for wideband input. HHH is more user-friendly in presentation IMO.
    Quote Originally Posted by Hans@GZP
    I have three as well man... LOL! Luckily, two of them are actually being used.
    3/S Street Tuner San Diego's fastest, daily-driven Panda VR-4 - fully gutted with lots of deletes!
    '92 VR-4 - est. 550AWHP VD U/C >> Phantoms @24-25psi w/ 8K RL on Pump-E85, BC264's, and GReddy EMU
    I snapped a rod after 10k DD miles into the build, and now Panda v3 awaits...
    New build in the works featuring AEM EMS S2, MHI EVO3 16G's, and methanol goodness
    supporter
    what version of evoscan do you have. I can't get 2.5 or 2.7 to use
    my com obd1 cable, the option is greyed out, but hhh works fine.
    Forum User Feedback Score 0 jbuhrman's Avatar
    Dec 2005
    Williamsport, PA
    Quote Originally Posted by bboyalan View Post
    Im OBD1 however having some issues getting it running correctly.. but in your area so when it is running I can get in contact.
    St. Charles, IL USA
    The issue is that the ODBI ECUs use a non-standard 1952 bps data rate that few USB to Serial chipsets support. Adapters build from the FDTI chips seem to support it like the Keyspan USA-19HS.
    I'm using 2.7
    Make sure you are trying to connect with a "1.3 cable" and not the "2.0 cable". The FDTI chipset is also a necessity. I found that out the hard way.
  11. The Following User Says Thank You to Hans@GZP For This Useful Post:
