Results 1 to 10 of 28
Thread: New Lat 42 1g front bumper-progress pictures
    Sponsor Feedback Score 1 (100%)
    North Shore MA
    Exclamation New Lat 42 1g front bumper-progress pictures
    I've been working on a new front bumper. It's part 2 of a 3 piece front end conversion I'm cookin' up. The headlight conversion is still in progress; you can see more here. I wanted to update the 1g front bumper to coincide with the updated look of the fixed lights. The idea is pretty simple: Remove the black mustache and open up the center for a front mount. I'm loving the way it's coming out.
    Step 3: A seriously mean top quality front splitter. But only if the headlights work out. So if you're interested get on the presale list!
    I kind of like the way it looks with the little slats on either side, but they're touching the pipes and keeping the bumper from fitting properly. I might have to get rid of them.
    I still don't know if I'm going to produce and sell this bumper. I'm probably going to make a fiberglass mold and 1 or 2 casts of it. If it works out well, maybe I'll make 5-10 for some lucky forum members. It's going to get cold here soon, so we'll see.
    Getting the PMP front mount kit to fit was a nightmare, and it leaks at the o ring. Still, can't beat it for the cost.
    (Everything is touching everything. The DN intake pipe is on at a rediculous angle, and that's after cutting part of the fan assembly and the fuse box bracket to make more room.)
    Kurt S.
    A.K.A. Lat 42
    A.K.A. "Fro Bro"
    December 2009
    Fox Cities, WI
    I like it...Along with the headlights.
    North Shore MA
    I was also thinking of making inserts that fill in the side openings. They would have a built in fog light and air duct. The ducts could go to the front calipers, or they could go to the oil cooler and air intake.
    Something like this:
    The only problem is that my FMIC pipes (pmp kit) fit terribly and stick out quite a bit. I don't know if I'll have enough clearance for a fog light.
    I found these - they're 3.5" round by 2.2" deep.
    If anyone knows of any 3"-4" round fogs that are thinner I'd appreciate it.
    I'm hoping to manufacture this bumper out of ABS plastic. I'm still not sure if the market is there though. Thoughts? Opinions?
    August 2009
    San Diego, CA
    keep in mind lat, make sure there is air flow to the oil cooler if you add fog lights.
    https://car.social
    RTV high temp copper silicone sealant will solve that leaky rear o ring and any other boost leaks you might have.
    the basic go fast bits...
    Tuned by Ray Pampena
    Just a fun Daily Driver.
    Heres an easy fix for your leaking o-ring issue.
    Take out the pipes to the rear turbo and plug all the holes in the turbo. Take a hacksaw or small handsaw and cut off the ear that the pipe bolts to (make you cut far enough out so its can stay round).Once you've cut that offtake a hand file and round out the small pieces that are still sticking out until it feels nice and round. Then take the pipe that goes in there and cut it off just after the weld so you have a smooth straight 2'' pipe, then bead roll that end.
    Now you just need a 2'' coupler and 2 t-bolts, its a bit of a stretch to get the 2'' coupler on there but it holds it on nicely, then just reassemble it all.
    Heres a pic of mine its a little messy right now from test fitting parts.
    And the list goes on...
    North Shore MA
    Both good options. I'm not going to cut them and use a coupler. It'd work well on stock pipes, but the PMP rear turbo pipe is all... stupid. It has this huge obnoxious groove to hold the o ring, and it applies no pressure on the o ring against the wall. Someone suggested putting the o ring in first, then tightening down the pipe onto the O ring. I might give that a try.
    ... plus some RTV if that doesn't work.
    North Shore MA
    wow, I haven't bumped this in a long time. The bumper is just about finished, I'm just filling in the gouges in the bottom from 20 years of abuse. I'm seriously considering having fiberglass reproductions professionally made. Let me know if anyone is interested!
    supporter
    Feedback Score 1 (100%) FeaRpb's Avatar
    In for final pics
    North Shore MA
    I started a new thread in my sponsors section but I'll put the info here too -
    The problem – 1g Owners cutting up their bumper to fit a front mount
    The solution – the revised OE bumper from Lat 42.
    Don’t think of it as an aftermarket bumper, think of it as an improved original.
    Key information:
    Looks and fits like an original piece – factory height, keep your AA, body lines match. Keep your original turn signals. They’re recessed like stock, but the indent is shallower for a sleeker look.
    -Improved cooling to your FMIC and/or radiator
    -No mustache or mitsu emblem
    -Must cut middle of crash bar, but no need to modify headlight buckets
    -saves some weight
    possible add ons
    Shroud to improve air flow to FMIC
    fog light inserts with ducting
    (excuse the mismatched headlights, my car hasn't decided if it wants a flipup conversion or fixed lights)
    I originally wanted to do ABS plastic, but headlight sales are slow and it’s not feasible. I’m looking into doing a flexible FRP reproduction. I’d need to get 3-5 COMMITED BUYERS that are willing to pay up front and wait a couple months for the reproductions to be made and shipped out.
    Pricing – between $300 and $400 depending on the number of committed buyers. I’m also willing to offer discounts to people who buy a bumper/headlight combo. So let's make it happen!
    Thanks,
    Kurt S.
    Latitude 42 Motorsports
