Results 1 to 10 of 15
Thread: front spindle castle nut?
    Cazenovia, NY
    I'm assuming these are only to be used once? I had to replace my hub and my castle nut threads are completely flat after I removed it. It just slides over the spindle now and I need another one before I can drive. Does NAPA sell castle nuts or do I have to drive all the way to Mitsubishi for one?
    Why? Because Race Car. verified Feedback Score 0 akotten's Avatar
    Wichita, KS
    I tried NAPA once for one of those and had no luck in my town. Its metric so they basically said no haha. I would just go to mitsubishi.
    91 R/T TT
    supporter
    Feedback Score 2 (100%) RealMcCoy's Avatar
    Medford OR
    I have no problem reusing them providing they are in good condition(obviously not an option for you at this point), but if you can't find a new one, I wouldn't be afraid of a good used one. Are the threads on the axle OK? You have any idea why it stripped the nut?
    Texas
    I have reused mine probably 30x
    Crazy thats yours did that. Check your axle, and get one from Mits. I remember seeing NAPA with one yesterday here, but I don't know if it was metric or not, but it appeared to be the right size and all.
    Cazenovia, NY
    Threads on the spindle appear to be OK. I'll call NAPA today.
    You can re-use the nut (provided threads are good), but you want to replace the lock washer behind it...
    It's sprung one direction and loses that after use.
    supporter
    I've never replaced the lockwasher and never had a problem.
    Texas
    Same here. The fact there there is a gap in the washer is going to cause it to lock, not really the spring out. Once you have so much torque, 144-180ft/lbs is what I believe the torque specs are, that washer isn't going to be "pushing" out anyway.
    thats fine, all Im saying is if you've seen a new one next to a used one they are different...I would then expect themto potentially perform differently.
    I'm not going to say there's going to be a problem, but to argue by saying "i've done whatever, and never had a problem" is not a good basis for a logical argument...just sayin, because I hear that alot.
    supporter
    Its perfectly logical but its personal experience. I've never had a nut back off so its not a real issue.
