Results 1 to 10 of 21
Thread: 4 Bolt Main Conversion
    St Joe
    Hey guys, I was talking to Matt from DR today and i realized I needed some more information.
    I am putting a 4 bolt main built engine (pics will follow in a few weeks) into my 91 RT TT. What are the differences in parts/procedures that I need to be aware of? thanks
    Edit: To answer my own question I did some digging and found these sites:
    http://www.stealth316.com/2-2bolto4bolt.htm
    http://www.wrenchmonkey.com/Webpages/4bolt.html
    However if you have any more information you'd like to add feel free!
    Why? Because Race Car. verified Feedback Score 0 akotten's Avatar
    Wichita, KS
    Something I should consider during this next rebuild...In for more info from people that have actually done this.
    91 R/T TT
    St Joe
    well to be honest the only reason to do this is if you get a block cheap. Throw a new forged crank in the 2 bolt. I think IPO has made around 800hp on a 2bolt main using the ARP 2 bolt main kit from 3sx.
    Forum User Feedback Score 0 1stStealthN/A's Avatar
    I did the John Monin 4 bolt swap but it's overkill for me. Two bolt with a forged crank would have been fine.
    Melbourne, Australia
    what is required if I drop a 4 bolt engine in my 1st gen that currently has a 2 bolt. Alternatively what is required fi I drop the complete 2nd gen setup in my car? I kow what is needed for drive train etc so just engine wise is there anything required? As far as I know th only difference is the CAS????
    Waiting install
    Build Thread
    Driving Vicki Crazy
    All you need for a 2 bolt to 4 bolt is
    4 bolt block
    4 bolt oil pan
    4 bolt oil pump
    4 bolt Alt/AC to oil pump bracket
    4 bolt Timing cog OR re mark a 2 bolt, the timing mark on a 4 bolt oil pump is moved versus the mark on a 2 bolt pump
    Of course, you could make over 700AWTQ and 800AWHP on a 2 bolt, so unless you are trying to make HUGE power, don't worry about it.
    -Chris
  7. The Following User Says Thank You to Ninja Performance For This Useful Post:
  8. #7
    supporter
    Feedback Score 6 (100%)
    Quote Originally Posted by Import Power View Post
    4 bolt block
    4 bolt oil pan
    4 bolt oil pump
    -Chris
    aren't the transmission stays and oil returns slightly different?
  9. #8
    4 bolt block
    4 bolt oil pan
    4 bolt oil pump
    -Chris
    Oh crap! I didn't do this. Is a 95 two blot NA cog different also? I was wondering why my marks didn't match up. I was thinking the heads might have been decked too many times or something. When all of the heads where lined up then the cog was off a little bit but not a full tooth.
    Edit: I also used the bracket off my NA. I had posted a thread about it but didn't get any responses. I did make it work but I had to do some shimming or something like that to get it to work.
    Yep, the stays are different, oil returns are okay. Also need 2nd gen timing belt cover.
  11. #10
    Driving Vicki Crazy
    Quote Originally Posted by 1stStealthN/A View Post
    Agreed.
    -Chris
