Results 1 to 10 of 15
Thread: Idle Issues
    Not A DSM verified Feedback Score 3 (100%) Polygon's Avatar
    June 2006
    Utah
    Idle Issues
    So, I've got an idle issue that's cropped up recently. The cold idle seems to be fine. However, the warm idle is a little rough. It also will come close to stalling when turning the steering wheel when not moving at time.
    Here's what's been done recently.
    EGR Delete
    New Intake Manifold
    New Valve Cover
    Plugs & Wires
    New Y-Pipe
    New Evo BOV
    New Rear Turbo Inlet Seal
    New PCV
    New Booster Check Valve
    Fixed Vac Leaks (Can't seem to find any more)
    New Air Filter
    So, does anyone have any ideas for what check next?
    Thermal Engineer- Mmbr Since:8/2005 verified Feedback Score 0 Alex3000gt's Avatar
    Indianapolis, IN
    Excuse my ignorance of our modded turbo cars. Do you still have an IAC? On my NA this was not working properly and caused my car to studder under load - like when your power steering pump pressurizes the lines.
    June 2006
    Utah
    Yep, mine is still on there. I've been wondering if I pissed something off on the TB when I changed the manifold. Maybe I'll trying pulling it off and cleaning it.
    Indianapolis, IN
    Yeah, cleaning mine with throttle cleaner did the trick. Also plug it in and see if it starts making noise when your car is on, the little motor in it should be moving. Mine also makes noise when the key is simply in the "ON" position, but who knows if yours will too.
    XLR8TOR Feedback Score 0
    Las Vegas, NV
    When you removed the ERG system did you do the 10 ohm resister trick. It is my understanding that the connector that used to plug into the EGR valve needs to have a 10 ohm resistor fastened between the two wires on the old unused connector so that the ECU still thinks that the EGR valve is there.
    Not sure what it does to let the ECU know but it should be done and it's easy enough.
    and a 95 too! Feedback Score 0 deemo99's Avatar
    April 2005
    Door Peninsula
    Quote Originally Posted by MaxClass View Post
    Hopefully someone else will chime in, but I thought the resistor was only to keep from getting a CEL? If this is for your 91 I don't know that the resistor is required. I removed my EGR on the 95, no resistor, no CEL.
    August 2009
    San Diego, CA
    Check your o2 Sensors? Hook a datalogger and see what it reads.
    When turning the steering wheel the car will increase the fuel/rpm a little and it may stall out.
    https://car.social
    Forum User Not Verified Feedback Score 0 blackrob's Avatar
    Raleigh, NC
    I have a very similar problem. I thought it might be the EGR since the CEL gave me a code 43, but I replaced the solenoid to clear the light. The warm idle is still rough until I start going down the road. Any ideas anyone?
    Moving on to reality. Sold my 3KGT, and now I am selling off my parts.
    Click here to see my parts for sale
    Is the idle just a little low?
    If thats the problem then try turning out you BISS screw a little to raise up the idle a little.
    And the list goes on...
    Sthrn NH/Eastern Ma
    Couple thoughts:
    1) Did you use an OEM PCV valve, and is it the correct one? Many of the aftermarket ones are either crap or incorrectly list the same valve for SOHC, DOHC, and TT. There are 3 different OEM parts for these. I've used Purolator on my NAs but OEM is the only way to go for turbo.
    2) Ohm test your IAC as soon as possible. Do it twice, both stone cold and warm. A bad IAC can destroy your ECU so get that out of the way before moving on to anything else.
