Results 1 to 9 of 9
Thread: DNP Hard Pipe Coupler Questions...
    supporter
    Feedback Score 4 (100%) CoopKill's Avatar
    Question DNP Hard Pipe Coupler Questions...
    I picked up a used set of DNP's without couplers.
    I have ordered 10 2" couplers and the TB reducer.
    Can someone tell me if I need another size/reducer for the IC or front turbo connections and what it is?
    Much appreciate any help...
    Bill
    Curitiba, Brazil
    That's what do you will need:
    1 3.0" to 2.75" Silicone Coupler Reducer Turbo
    4 2.0" Silicone Straight Coupler
    4 2.0" Silicone Hump Hose
    I take all them on votionspeed.com
    Hug, Chris
    Norfolk, VA
    Eight 2" couplers is wrong; completely wrong. First, there are 9 couplers, not including the TB one. Second, the ones between the DNP piping and ICs is of a reduced size (the piping kit tapers at those connections).
    IIRC, the connections are as follows but I'll admit that I'm not 100% sure this is accurate (hump connections are a personal preference and not required; I used all straight or reduced connections):
    4 2"
    4 1.75" to 1.5" (piping to IC connections)
    1 1.5" (front turbo to piping connection) - I am least sure about this one, it has been several years.
  4. The Following User Says Thank You to AlmosN8kd For This Useful Post:
  5. #4
    Curitiba, Brazil
    Quote Originally Posted by AlmosN8kd View Post
    4 2"
    You right. Sorry.
  6. #5
    Norfolk, VA
    Quote Originally Posted by Chris View Post
    You right. Sorry.
    It's cool man (I think I came off a bit smug when I re-read my post, sorry about that, it wasn't my intent). I also tried the "all 2" connections" at first myself which is why I know it doesn't work. Unfortunately, at the time I installed my piping kit, I was in a rush and didn't have time to wait and order the proper couplers, so I ran down to the local parts store and bought some radiator hoses that had the right size reducers on them (cut the section off that I needed) and have been running them ever since. Yeah, I know, completely ghetto but they hold and they're all the connections that are buried in some way so you cannot see them.
  7. #6
    supporter
    I changed my order from Columbia River Mandrel Bending, aka Vortex Induction Sports, aka siliconecouplers.com.
    Hopefully they get the memo before sending out. If not, a trip to Saint Helens is in order...
  8. #7
    Forum User Not Verified Feedback Score 0 Keyan's Avatar
    As said already, the DNP pipes taper off to stock size at the end of them. So you need 1.75" couplers. OR, you could do what I did, and cut off the taper and weld in just straight 2" and then get a 2" intercooler set up, and you can have a FULL 2" charge piping setup. You can feel more power. (less restriction, more cfm at same psi)
  9. #8
    supporter
    So, What size are the IC pipes? Do I need 1.75 to 1.5 reducers?
  10. #9
    2004/5?
    SW Connecticut
    Oh man, I had a thread just like this back at the other site a month or two ago and got no replies...
    Basically I ended up ordering all 2" couplers which was an obvious mistake. I still want to replace the rest though, so I'm also very interested in the sizes required.
    Thanks!
    -Caleb
