Results 1 to 10 of 22
Thread: CV Joint grease
    Forum User Not Verified Feedback Score 0 GordonRamsey's Avatar
    Earth
    CV Joint grease
    After installing my TT brakes, my CV joint seems to be leaking alot of grease. Could I have bent it too far possibly by trying to get the spindle off? How long will it last by loosing grease every drive?
    “What's the use of a fine house if you haven't got a tolerable planet to put it on?”
    cheshire, england
    you have either split or popped the boot off the joint, best to clean that off and check it. axles are fairly cheap to buy. but dont have that grease flying everywhere its horrible stuff.
    how long will it last? centrifugal force will squeeze the grease from the joint all together and you will end up with a dry joint that will fail.
    best to address it now rather than later.
    Earth
    well its definitely not slipped off. its tight on there. ill go look for openings.
    Earth
    hmm, nothing that I can see. The clamp is tight but it is everywhere. it looks like its seeping through behind the clamp there. Is there supposed to be an arch in the clamp?
    Earth
    I suppose I should get new ones anyway, seeing as how I'll be racing soon.
    cheshire, england
    sorry was elswhere. no there should not be any arches in the clamp bud. sounds like its trapped on something. try autozone for prices. they will me remanned but they are as good as new.
    Earth
    hmmm, they both have it though and the other side isn't leaking a thing. It definitely looks manufactured into the clamp. I guess, I should buy new ones anyway.
    On another note, how well do brand new 3sx ones handle aggressive driving?
    Forum User Not Verified Feedback Score 0 Keyan's Avatar
    yes the "arch" is how they pinch the clamp tight. just replace the axle. once the boot opens up, dirt gets in there and its done. you COULD replace just the boot but its easier to do the entire thing; and the dirt will grind away at the needle bearings.
    Earth
    $100 is cheap, even for 3sx. I Think I might replace all of them just to freshen it up.
    Earth
    Hmm, buying one side axle and not the other wont make it favor one side in acceleration will it? Seeing as how it will most likely rotate smoother.
