Some of you may know about the single turbo system I had built for my car a few years ago. To be honest, I had originally built it half-assed, more to prove a theory of turbo placement and the complications of its location as well as the long tube length and pulse mis-match. The old system I had built with off the shelf ebay manifolds and left over roll cage tubing I had laying around, again, just to prove a theory on the low-buck. That system, on a GT4094R made 673hp and 6xx torque and performed fairly well at 24psi on a road course. Well the time had come that I do it correctly with the proper length of tubing, calculating the long side to match pulses and ultimately a system that didn't generate a 3-1 (yes, 3-1) pre-post turbo pressure ratio. (scary isn't it?) I had heard about the 350z manifolds and how well they match up. They kinda do, kinda. This is by no means an afternoon project, 4 months in fact, is what it took to make it work. I have loads of pictures and will do my best to give everyone that wants to take on this challenging endeavor upon themselves a bit of insight as to what it takes. A few things will be left to your own interpretation, not to give the farm away, as to why some of these lengths and sizes are the the way they are. Over the next few days I'll post up a number of pics and how it all turned out but I'm rather excited to share my findings. I fired up the car for the first time over the weekend and the initial results are good. My tuner had to make a tremendous amount of changes as the volumetric efficiency has significantly changed. Enough, pics..
This is what I started with, old vs. new in the attached pics.
Also, a pic of a crack I found on the old system. I know, it's fairly thin walled. It's light, and will crack over time. No worries, I have a welder and typically do inspections before races days in advance.
A nice pic of some of the 304L stainless I'll be using too.
